Leaking Cam Sesnors/Oil in Engine Harness/ECU
2013 ML63 48k miles
History: Truck ran amazing tuned and untuned. E50 Eurocharged Tuned By Jerry
Had CEL for misfire, took in for service and noticed that #7 plug had an electrode that was closed shut. Did leak down and compression test came back normal. Replaced all plugs and it ran fine again but then started to have a slight miss/vibration at idle but would throw no codes. Power was down. I replaced all ignition coils with updated part #s, no change. Then noticed I had oil in camshaft sensor, replaced all sensors and it ran great for a bit. Miss came back no codes and down on power. I noticed I had slight oil on ECU blades oil on cam sensors and on 4 of the fuel injector harness connections. Cleaned up all with contact cleaner and let sit for a few days. Truck runs good but its still "off" but wont throw codes. I think the entire engine harness is fouled with oil and needs to be replaced. I cannot get to the front two 02 sensors to see if they are fouled.
Engine has slight rough idle that comes and goes. Power is down, I get a delay in boost onset in-between shifts. Im lost, I just ordered all new cam solenoids. The only thing left is to replace the entire engine wiring harness. Has anyone encountered this issue to this extent? Any help is appreciated.
