Dragy results of my stock 14 E63s
Old Jan 31, 2021 | 08:02 AM
Juice1979's Avatar
E550
normal stock 60-130 is about 9.0 seconds
when is the last time you had plugs changed? Coil packs changed? What gas, your engine may be pulling timing therefore reducing power
I think 9.0 is a little fast for a stock S model. I'm only hitting 9.6 in negative DA. My 1/4 trap speeds are in line with a stock car so I know my car is performing as it should.
Old Jan 31, 2021 | 01:05 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
Originally Posted by Juice1979
thanks, no race start or brake boosting. Just floored it off the line.
Congrats on the car it looks beautiful - you will love it especially once you start down the mod path and start seeing how easy it is to make more power with this amazing M157 motor.
You may want to start with simple mods like Blackboost intake then TCU tune (or vice versa) and new tires to get a feel for the significant power improvements from just those and a stock ECU. After those, do an ECU tune from any one of the reputable tuners which you can read up on these forums to get members feedback on each of them (do a simple search) and then maybe tuning for meth as the last step which many on these boards are doing now.
Congrats you'll enjoy turning this into a 10 second car very quickly
Old Jan 31, 2021 | 01:06 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Looking forward to trying out the Dragy.
Just need the roads to clear up.
Aiming for 10 seconds I guess.
Old Jan 31, 2021 | 02:21 PM
Juice1979's Avatar
E550
Thanks! I am very familiar with the m157, I just sold my 13 cls63 that had a custom Eurocharged dyno tune.
Old Jan 31, 2021 | 09:36 PM
BenzoDoc's Avatar
2015 E63S 4Matic
Originally Posted by BenzoDoc
67K miles.
Filters were changed in April 2020 with 66k miles [so <1k miles on the filters].
Coils and plugs all brand new as of 10/29/2020.
Brand new rear tires in 11/2020.
Sorry I'm also in Chicago so was busy today making sure I could make it out to work tomorrow.
I had mentioned above that the coils and plugs are all basically brand new <1000 miles ago on 10/29/2020. OEM Mann Air Filters in 04/2020.
Gas is 93 octane from BP, Mobile, or Costco in Lincoln Park. Based on a recent thread that mentioned running E30 on stock tune being safe I had considered trying that to see if there was any difference [once there isn't a foot of snow].
Old Jan 31, 2021 | 10:38 PM
I would try a few more runs to see what you are running on a stock tune with 91/93 octane before trying to run e30.
Want to make sure the car is running in tip top shape making the power it should before trying to make a ton of more power.
We don't have a foot of snow here, but definitely in the middle of winter
Old Feb 1, 2021 | 12:28 AM
  #32
PeterUbers's Avatar
How did you do the 60-130? What technique
Old Feb 1, 2021 | 04:17 PM
  #33
Great question.
A 1 second difference reflects a decent drop in performance (11 seconds instead of 10 seconds).
Wonder how a test at 3000 feet elevation will be affected?
Old Feb 2, 2021 | 12:13 AM
  #34
BenzoDoc's Avatar
2015 E63S 4Matic
sport plus. Downshifted repeatedly until revs were near top of gear. Hit it from ~45mph.
Old Feb 2, 2021 | 11:03 AM
  #35
How many 60-130 runs have you tried?
A bad tank of gas?
Old Feb 2, 2021 | 11:59 AM
  #36
nota_amg's Avatar
2013 SL550 BiTurbo
here is my lowly M278 qtr mile on dragy
0-60 is 3.14 seconds. (1ft)
60-130 was high 7's, don't remember exactly, 7.8 I think?
Last edited by nota_amg; Feb 2, 2021 at 12:04 PM. Reason: Added 0-60 time & 60-130 time
Old Feb 2, 2021 | 01:53 PM
  #37
Juice1979's Avatar
E550
Great numbers for a e550. Impressive 0-60
Old Feb 2, 2021 | 05:31 PM
  #38
nota_amg's Avatar
2013 SL550 BiTurbo
thanks, she is a beast.
Old Feb 2, 2021 | 09:17 PM
  #39
billvp218's Avatar
m157 SL63
That trap speed is not high 7's for 60-130.
If you took 3.39 0-60 (non 1-foot roll-out), then it would be 8.0 from 60-121.65 based on your 1/4 mile. 121.65-130 at your trap speed is probably 1.5s, so I'm guessing your 60-130 is more like 9.5s or higher. A stock e63s with similar trap speed takes 10.0s.
High 7 second 60-130 m157s trap 130+.
Old Feb 2, 2021 | 09:24 PM
  #40
Juice1979's Avatar
E550
I agree his trap speeds indicate a high 9-10 sec 60-130s. We have similar traps and my 60-130 is 9.6. This is on a stock 63s model.
However, cars running high 7's for 60-130 don't need to trap 130+. My old cls63 trapped 125-126 and ran 7.95s 60-130.
Old Feb 2, 2021 | 09:34 PM
  #41
billvp218's Avatar
m157 SL63
7.95s 60-130 with a 125 trap in the same conditions? I'd be interested in seeing the dragy. Sometimes they flake out (maybe temporary loss of signal or whatever) and you can tell by spikes in g-force.
If you take off about 0.7s for 125-130, that's 7.25s from 60-125. A 3.5s 0-60 would mean you were running 10.75 @ 125. Were you?
In reality, a car running 10.75 @ 125 is probably not running a 3.5s 0-60, they are much quicker off the line than that which lowers the ET.
Old Feb 3, 2021 | 06:37 AM
  #42
Juice1979's Avatar
E550
All runs were in negative DA ranging from -300- -800 and times were repeated. My ETs were mid to high 11s with a 0-60 of low 4s. I was rwd running on all seasons and could never hook off the line. If you search under my username you should be able to find the old posts with dragy screenshots
Old Feb 3, 2021 | 08:39 AM
  #43
boostedbenz.com's Avatar
SPONSOR
12 E63AMG and 19 GLC63AMG
Hello, there is a very good thread on MB world already simple mods to break 10S and not blow a lot of money I highly suggest to take a look at it.
https://mbworld.org/forums/w212-amg/...-part-two.html
Old Feb 3, 2021 | 09:40 AM
  #44
nota_amg's Avatar
2013 SL550 BiTurbo
like I said, I THINK it was 7.8
I'll pull it up when I'm out of the Fab and take a look.
Old Feb 3, 2021 | 01:28 PM
  #45
billvp218's Avatar
m157 SL63
The dragy results shown here https://mbworld.org/forums/w212-amg/...ml#post8021819 have the spikes that I was talking about, in g-force. This means something was off with dragy on those runs. You can see much shorter elapsed time between a section (130-140, or whatever) than normal when the spike is there compared to other runs when it was not.
If you still have your old dragy results saved on your phone, you can check and see what your best time is that didn't have any of the g-force spikes. They're not super common, but they do occur and seem to happen to some people more than others - I'm not sure if it's related to a particular location with a relatively poor GPS signal, or the dragy not being mounted securely, or what. Regardless, if you only saved your "best" results and deleted others which (perhaps confusingly at the time) were a decent amount slower than your "best" times, then unfortunately you may only have the spiked ones saved - which are not true indicators of performance.
You can sort of splice the two dragys in the linked post together, although there is unfortunately still a spike between 120-125 in both runs (one negative, one positive). Note I'm not cherry-picking which sections to combine, this is just to get rid of the spikes. If you take the 100-120 from the top run since there is no spike in that section, and add it to the 120-200 in the bottom run, you end up with 7.07 100-200, although that still has an optimistic spike between 120-130. I'm guessing 7.2s or so is around what you would average with no spikes, with maybe an 8.4 60-130 aside from the outlier (spike) runs. If you have all your results saved, we can see though.
Old Feb 3, 2021 | 02:36 PM
  #46
Juice1979's Avatar
E550
unfortunately I got a new phone and lost all my previous unposted dragy data. I know about that spike in that run. I did have another best of 7.96 with no spikes that wasn't uploaded. I also had a bunch of 8.0xs that I ran as well. Here's an 8.2 before I figured out a better technique. And here's and 8.12 on a positive 2.3% slope!
Old Feb 3, 2021 | 04:11 PM
  #47
PeterUbers's Avatar
very nice run! Nice DA too
Old Feb 3, 2021 | 05:44 PM
  #48
BenzoDoc's Avatar
2015 E63S 4Matic
Originally Posted by kenneyd
Haha, I just started a YouTube channel, for now I've named it exotic car diy. I hope to just document and show that basically anything can be done to any car DIY. I've done all the maintenance on all my cars including my 355, I'm just going to film anytime I do anything now. The only problem, is I hate being on video lol
How many miles? When was the last time you changed the air filter? for me it netted me 0.2 in both the 0 to 60 and quarter mile time just by getting a clean filter in there Maybe try resetting the computer and trying again?
67K miles.
I'm actually very appreciative of your timely video. I ordered some filters from amazon given how cheap they would be to just drop new ones in. Figured that it couldn't hurt to have them around. I was postcall today and had a chance to pop out my old filters and install the new ones if needed.
I'm fairly suspicious that the filters I pulled out have more than 1k miles on them, and that the dealer did not switch them last spring. [which is another issue altogether, will have to talk to my SA]. These probably go back as far as when I bought the car in 12/2019, and who knows how long before that, will need to check prior owners records.
I also noticed when removing the airboxes that my passenger side intake tubing was unraveling [I had replaced the driver's side which had visibly ripped previously using the Spectre tubing method]. I figure if a defect allowed for suction events or turbulent flow that could also be causing some issues with the 60-130 times [if it wasn't the leaves above].
A bad tank of gas?
Dozens of pulls, but prior to my recent Dragy purchase. I head in to the hospital between 430 and 530 everyday so I usually get a decent pull whenever I want because there are so few people on the road. Unfortunately Chicago has been very snowy recently and has put a damper on that.
Old Feb 3, 2021 | 05:58 PM
  #49
kenneyd's Avatar
poop
Yours looked like mine. My car had 11,100 miles on is and the records show it was serviced a dozen or some times. But the filters were nasty. My theory is these m157 suck A LOT more air the other models, thus they should be change more than whatever the current interval is. I bet you're gunna feel a little performance bump like I did
Old Feb 3, 2021 | 06:08 PM
  #50
nota_amg's Avatar
2013 SL550 BiTurbo
Well, poo...
Yep, totally wrong. 😂
this 60-130 time was actually done the same run as the 1/4 mile one I posted yesterday. Ran the 1/4 and then out to 135 mph before shutting down.
