Loweringmodule.com....
Old Feb 1, 2021 | 08:04 PM
C2 Turbo's Avatar
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
Anyone tried it yet? Any feedback?
http://loweringmodule.com/mercedes/e...-2014-present/
Old Feb 2, 2021 | 04:21 PM
Rehabguy's Avatar
E63S
If you are trying to lower a w212... know that ANY module would only control the REAR ride height. The front needs old fashioned lowering springs. Do the adjustable links everyone uses... unless you think you need to be constantly adjusting your rear ride height for whatever reason.
Old Feb 2, 2021 | 06:02 PM
nota_amg's Avatar
2013 SL550 BiTurbo
yeah, the module is nice and easy, but something like this is all you really need: https://www.ebay.com/itm/MERCEDES-E-...-/122650138754
...unless you have a wagon
Old Feb 2, 2021 | 06:58 PM
C2 Turbo's Avatar
Yup, it i a wagon.... how does that change the parts?
Old Feb 2, 2021 | 07:24 PM
nota_amg's Avatar
2013 SL550 BiTurbo
wagons have bags in the back and steel springs up front. gotta get springs to lower the front, rear can be done with links.
Old Feb 3, 2021 | 03:04 AM
SAMzE63s's Avatar
E63s
wagon or sedan, both the same.
both have bags in the back and springs upfront.
Old Feb 3, 2021 | 09:28 AM
nota_amg's Avatar
2013 SL550 BiTurbo
oh, that I did not know...not setup like the w211. cool.
Old Feb 3, 2021 | 10:17 AM
tpick23's Avatar
E63
Thanks for info but that link says not suitable for E63. Is that correct. I would like mine a bit lower in the rear and leave the front alone/ Thanks
Old Feb 3, 2021 | 07:07 PM
JeffJacobson's Avatar
W205 C43 and W212 E63S
Just get KW Adjustables for the fronts and links for the rears and call it a day.
Old Feb 3, 2021 | 07:15 PM
C2 Turbo's Avatar
Better than the H&R set up? Differences?
Old Feb 3, 2021 | 07:31 PM
So, as far as I know, there are no Adjustable fronts from H&R for the E63s. So you are set at what height you get. The KW’s + links you can adjust to whatever height you want. BTW, this is moacur from Rennlist.
Old Feb 3, 2021 | 07:39 PM
For me, I did the KW’s plus links first, which was plenty low for most, but I wanted lower, so went to
https://scalesuspension.com/shop/en/...original_color
and completely removed the air from the rears and went full coils with damping. The KW’s ride extremely well, even completely spun all the way down.
Old Feb 3, 2021 | 07:52 PM
C2 Turbo's Avatar
Small world, how are ya. Do you have an E63 too? I really don't plan on moving the wagon much so one setting would do. If KW's are still better than that's what i would consider.
Old Feb 3, 2021 | 08:02 PM
Very good and hope you are the same! I do, Have a 2015 E63s sedan, but it is pretty different as I had the rear fenders pulled 2” to match the fronts.
Old Feb 3, 2021 | 08:05 PM
Before I went coils, had the KW’s and would highly recommend them as they rode great and were very comfy
Old Feb 3, 2021 | 08:26 PM
C2 Turbo's Avatar
looking great, what size wheels are those?
What's the difference between the Tt & KW? Looks similar, no?
https://modbargains.com/kw-height-ad...w218-25325071/
https://www.renntechmercedes.com/ind...springs-detail
Old Feb 3, 2021 | 08:41 PM
I’m running 9.5 et30 and 11.5 et20. Stock is good at 9.5 et30 and 10.5 et40.
KW’s are just springs and adjustable perches.
Old Feb 3, 2021 | 08:43 PM
Have not run the Renntech kit, so not sure
Old Feb 3, 2021 | 08:45 PM
C2 Turbo's Avatar
What size tires with the sizes mentioned above?
Old Feb 3, 2021 | 08:50 PM
255/30 and 305/25 or 245/30 and 285/25 both work great, just depends on how low you go. If you’re lowering just a bit, go 255 and 305.
Old Feb 3, 2021 | 08:57 PM
C2 Turbo's Avatar
Will PM you later, few wheels/tires questions
Old Feb 3, 2021 | 09:00 PM
Sounds good. Can message me on rennlist as well. Much more active there
Old Feb 6, 2021 | 10:09 PM
enfox's Avatar
e55
Did you have any error codes swapping out the front suspension to non oem?
Old Feb 8, 2021 | 08:23 PM
Ed99's Avatar
E63s AMG
I am currently running KW HAS Kit for over 3yrs without any issues and love how the ride and the capability of adjustments to your likings. Can't go wrong with KW HAS and pricing is pretty decent too. Not overly expensive.
