Accessing front camera view quicker?
Old Feb 9, 2021 | 03:21 PM
Mojo20032004's Avatar
2014 E63S
Is there a easier way to enable the front camera when pulling into a parking spot that has a curb? I always see myself going into reverse first to activate the 360 cameras, then back into drive. Kinda of looks goofy, and sometimes a inconvenient. Would be nice if there was a quick access button to turn this on like the BMW M5 has.
Old Feb 9, 2021 | 04:35 PM
NoVAe63s's Avatar
2016 E63s
I hit the car icon button, then select 360 view. If there's a one-button cheat I'd like to know too!
EDIT - I see you meant front camera, looks like if you are in drive or park it will show the front cam.
Old Feb 9, 2021 | 04:58 PM
2014 E63S
It shows the front cam up to 20mph. After that it goes back to what ever screen you had it last,and to get to the camera screen under 20mph(only time it will activate) you have to go through some menus to enable it. I just kind of want maybe a click or 2 and boom it's on
Old Feb 9, 2021 | 08:24 PM
_KO_'s Avatar
2015 CLS63, 2020 GLC300 Coupe
Another “shortcut” which is still kinda long is holding the vehicle icon button for like 5seconds.
Brings up the camera tho
Old Feb 9, 2021 | 10:52 PM
Rehabguy's Avatar
E63S
I press "SYS" button while in Drive (obviously w/ brakes applied). Then use menu to to select 360. It will display front view for exactly this purpose.
Old Feb 10, 2021 | 05:45 AM
JTS97Z28's Avatar
2014 AMG E63S
Yup, as mentioned above just push and hold the system button to the left of volume. The other way they said above is the second quickest way. This is one push 360cam access which is nice when you’re pulling into a parking spot and want it up quick.
Old Feb 23, 2021 | 06:08 PM
2014 E63S
So figured out holding the "sys" button for 3 seconds automatically turns on the 360 camera while in D.
Old Feb 23, 2021 | 06:59 PM
JTS97Z28's Avatar
2014 AMG E63S
lol didn’t you read any of the replies to your original post above? There was like two people that said to do that 😉👍🏼
Old Feb 23, 2021 | 07:29 PM
hardyli's Avatar
Lincoln
Nice! I didn’t know HOLDING it will trigger.
Old Feb 23, 2021 | 10:29 PM
2014 E63S
There's isn't a vehicle button, I looked for it. Everyone mentioned about using the knob
Old Feb 23, 2021 | 10:34 PM
JTS97Z28's Avatar
2014 AMG E63S
What about replies 5 and 6? 🤷🏼‍♂️ Either way, glad you figured it out.
Old Feb 23, 2021 | 10:44 PM
2014 E63S
Ah I see #6 missed that one.. Good call.
Old Feb 27, 2021 | 03:50 PM
nsoltz's Avatar
2023 EQB300
Hoping for dashcam activation on the 2021's. Not an option in US but hopefully they are working on coding a purchased unlock. I helped a friend order a GLB and he was able to order dashcam on GLB.
Old Feb 28, 2021 | 11:13 AM
_KO_'s Avatar
Sorry. On mine it’s a vehicle icon. I guess just to clarify if anyone else is looking
Old Feb 28, 2021 | 01:23 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Thanks.
The camera can be brought up while moving slowly (not sure what speed this option is locked out), but as I approach my parking spot can hit the button and have the front camera image pop up
VERY helpful and easily done without fiddling with the knob which was how I did it before this great thread
As mentioned in my 2015 E63s the button to push is the SYS button.
Old Mar 2, 2021 | 09:44 AM
cotmfk's Avatar
On the shoulder
Works perfectly, thank you!
Old Mar 2, 2021 | 10:06 AM
2014 E63S
If u hold the button down it will automatically engage the 360 camera without the use of the knob at all
Old Mar 2, 2021 | 02:34 PM
Rehabguy's Avatar
E63S
No problem!
I didn't know about the holding the button down option. Thanks to whoever brought this up. I tried it out today. It splits your center screen up in 3 vs the method I suggested only displays front view. I found it a bit distracting to have the sides included in the screen as oppose to only viewing the front. This is definitely personal preference, of course.
Old Mar 9, 2021 | 07:13 PM
Rehabguy's Avatar
E63S
Holding down SYS button for ~5 secs
Tapping SYS and then using knob to navigate to 360 view. I def. like the bird's eye for reference as opposed to the 3 way split view
And since I don't regularly drive my car and I had doubts about that "vehicle button"... mine doesn't have it.
Cheers, guys.
