Trunk won’t open, rear backup lights and camera don’t work
The only way to open the trunk is to use the manual key in the trunk.
I feel that it may be the SAM. I’ve opened up all the interior trunk panelling and all wires seem in tact and no moisture to be found. Any ideas?
- Remove plastic cover (unsnap several tabs) on the left hinge.
- Undo soft wrap insulation on the wire bundle.
- Locate the thickest (brown) wire in the bundle where the bundle leaves the hinge. You will not miss it; the 20cm section where it flexes.
- Trace it to locate the break and repair.
- Test and reassemble.
Hope this helps.
will give a full rundown of the fix when it’s back. On a positive note, I think I’ll tune my car while it’s at the independent repair / performance shop.
Hope this helps.
