2013 E63 HVAC inlet part number needed
13 E63 Estate, 02 ML500
Hello,
I'm in search of the part number for the plastic air inlet box that sits above the main battery in the engine bay on the passenger side near the cowl. Just purchased this E63 Estate and it's missing this plastic box and I can see straight into the blower motor fan. I'm sure it's sucking in hot engine air to the passenger cab at this point. I've scoured the online MB part websites and drilling down on the body -> cowl section, I can't seem to find any info for the 2013 year. The attached parts photo is what I'm in search of. If someone can find me a part number of their existing, that'd be great!
Welcome to the forum. Your part number is called the air intake housing #50 p/n A2128300103 cost is $80. You may also want to check if you have the top clamp #60 p/n A0019917570; side clamp (not on diagram) need 2 #110 p/n A0019917470; valve #70 p/n A2128320084; front fitting #150 p/n A2128320825; nut-and-washer assembly M6 #160 p/n N00000004011. Hope this helps.
