Esp, Abs, Srs lights on dash car wont go into gear
e63 w212
hey guys hope someone can help 2011 e63 the other day i was driving car ran great came home and about an hour later went to restart to run out again and noticed a bunch or xmas lights on dash. the abs, esp inoperative, srs, check engine on and the auxiliary fan running on high.
the best part the car wont go into gear stays in park. i connected the launch x431 and tried to clear the codes and wont even clear them. disconnected the battery and let it drain for a while and started and went in to drive again
Had similar thing happened to mine ( 2002 E55) and it turned out to be the Brake switch. Please google and see if your model has a brake switch ( I am sure it does) and start there. Cheap, quick and easy fix.
Hope that helps.
Hope that helps.
