Inoperative message after wheel bearing replacement
1. Powertrain System: produced primary trouble code:C0034 Right Front Wheel Speed Sensor
2. ABS Anti-Lock Brake System produced primary trouble code: 445800 The Signal Of Component ''L6/2 (Right Front Axle Rpm Sensor)'' Is Implausible.
I disconnected just the break pad wearing sensor and nothing else. I guess somehow I touched the speed sensor when removing the the caliper and rotor. Still not sure why the ESP is off. I thought I could save a few hundred bucks by replacing the wheel bearing myself but it's getting expensive when I broke something else. :-) By the way, it's not a very difficult job, I now know how to replace brake pads and rotors. Be careful when hanging the calipers and not damage the wires/sensors. The most difficult part was to remove the bearing races. The inner bearing race was pita to remove.
Now I got the "check brake pad wear" message because I tried to remove the wear sensor but I couldn't.
Fix one thing and break something else is always the case. Must have extra parts when trying to fix something.
