PO351
I had the plugs done at 51,000miles with stock plugs before adding the tune. Silly me i didnt have the coils done at the same time. My bad. I didn't know.
About a month ago after a 5 hour drive under heavy acceleration i felt a stumble. No codes thrown. I was low on fuel and figured maybe some poor fuel. So the next day put some good known 95 octane fuel in and off i went.
Last weekend, doing same drive, almost same spot heavy acceleration it did it again. Except this time it threw a CEL for misfire cylinder 1. Ok. Short research, bad coil packs most likely. 1 and 5 are the first to go.
I just replaced all 8 coil packs tonight. Took the car out. Seems to run smooth as ever. Let it warm up and get into the throttle hard and same stumble. No CEL, but it did come up pending code PO351. Iqnition Coil "A" Primary/Secondary Circuit. Under normal driving and light to medium throttle no issues. No stumble. Only under full throttle 3rd or 4th gear.
Any thoughts? Spark plug? Bad coil pack batch? Bad fuel? Weird its the same cylinder 1
The only reason I picked up an aftermarket set from the local autoparts was no body had a set anywhere. I must have called a dozen dealers across the country. Luckily today FCP Euro had them back in stock. I'm going to return the off brand ones and install the Bosch OEM.
Clearly lesson learned, about OEM stuff. I got nervous and just grabbed whatever I could get last week. But next time I'll be sure to wait for the OEM stuff.
