To get best launch
Old Nov 8, 2021 | 10:09 PM
Z34TTS's Avatar
E63s
To get best launch
Trying to learn more about how to launch
So far my best 60ft is around 1.83 done with brake boosting and sport handling 2600-2800 rpm( wanting to get in the 1.7x)
So what i see if you use the brake and has it builds as soon as it gets to around 3400 it goes into like a limp mode.
Tryed to hit it at 3200 ish tonight and that must be to close as well. Bogged out but went
So what do you do find that work the best? And can anybody explain how that system actually works with a limp mode and what point it cuts off just bogges why anyting etc.
Old Nov 8, 2021 | 11:28 PM
PeterUbers's Avatar
Do you have a tcu tune?
Old Nov 9, 2021 | 03:09 AM
Z34TTS's Avatar
E63s
not that im aware of.
Old Nov 9, 2021 | 07:13 PM
PeterUbers's Avatar
I have a tcu tune so my car doesn't bog like yours does... anymore
launching a stock tcu is rough on these cars
60ft is rough
Old Nov 10, 2021 | 08:51 AM
BCP's Avatar
BCP
2014 E63s
Comfort suspension, TC off usually works best for launching, and you def cant hold the car on brake boost for a period of time. You are going to be limited by the TCU though - a TCU which allows more torque in the lower gears will net a quicker 60ft. What mods are done to the car? That's an unusually high launch rpm for brake boost.
Old Nov 10, 2021 | 08:59 AM
Mojo20032004's Avatar
2014 E63S
if u have a ecu tune, dont launch past 2k or u risk breaking stuff. as mentioned above a tcu tune lets you use all the available power down low, so you can launch without that bog
Old Nov 10, 2021 | 09:05 AM
Z34TTS's Avatar
E63s
As far as i onow the car is stock...some think it may have a ecu tune...the exhaust is all stock and im beginning to smell the catalytic converters burning now. Making a smell
Old Nov 12, 2021 | 09:26 AM
Blade Canyon's Avatar
2012 E63 AMG
Does your time change at all if you use Race Start?
