Can't figure out where the headlight control module and ballast voltage converter are
Old Dec 12, 2021 | 12:41 AM
maxknuckles's Avatar
e63 wagon 2014
I can't figure out where the headlight control module and ballast voltage converter are located. Any help locating would be great.
I believe the ballast voltage converter is under the headlight? Can this be changed without taking the headlight out?
Old Dec 12, 2021 | 08:15 AM
kenneyd's Avatar
poop
Sometimes looking for the part on eBay for pictures alone can be very helpful, I would imagine it's on the bottom of the light. I will check later as well as the EPC
Old Dec 12, 2021 | 11:47 AM
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
Bottom of the headlights. Front bumper need to be removed to allow room for headlight removal to access them.
Old Dec 12, 2021 | 06:28 PM
SAMzE63s's Avatar
E63s
Bottom headlight.
I believe coding is needed if you replace them. Not 100% sure
Old Dec 12, 2021 | 06:41 PM
WANTED!!'s Avatar
Originally Posted by SAMzE63s
Bottom headlight.
I can verify it is indeed needed.
