Adding ceramic brakes
But it’s ok they offered 15% off so only CAD $27,200.
Keep in mind the Racing Brake kit is only 390mm and not 402mm. Another difference it is continuous fiber and not chopped fiber.
There’s a full used takeoff at 5,000 miles from a GTS for sale right now in the UK for $12,000 pounds whatever that converts to USD.
Ebay has used ones once in a while for $8-10k
Keep in mind you don't want to use the current single piston rear calipers, you will need the older 2016 type rear calipers.
