I noticed oil on my garage floor today so I decided to have a look around dusks for areas. Mercedes only serviced it 3 weeks ago and a good I dependant did gear oil change 4 weeks ago and there were no signs of leaks.
so quite suddenly it’s leaking to the point it’s all over the bottom of the underside catch tray and now dripping onto my garage floor (albeit 3 small drops)
I have had a look around the valve timing covers and couldn’t find anything around the top. But where the oil filter housing is I found evidence (pictured) of oil leaking.
are the filter housings known to be an issue or is it more likely the valve cover leaking into the housing from a spot that I can’t see without taking it apart.
I bet they made a mess doing the oil change and not an actual leak. I'd clean all the oil up best as possible, rags/parts cleaner spray and wide down the catch tray panels underneath the car and see if its really a leak or just sloppy oil change.
It is on the filter side though and it has been a few weeks now.
I have located the leak to be either the upper timing chain cover or potentially oil filter housing.
The motor has 150k kms on it so whilst I’m in there fixing this I was thinking of changing the following:-Water Pump
Water Pump metal gasket
Thermostat
Thermostat O-ring
Thermostat elastomer
Camshaft Position Sensor x4
Camshaft Solenoid O-rings x 4
Oil Filter Hosing main real seal and o ring
Oil filter housing temperature regulator
Oil filter housing regulator cap
Oil filter housing regulator spring
Guide Pulley with Tensioner
Guide Pulley
Guide Pulley
Idler Pulley
Oil Cooler seal with carrier (next to oil filter housing)
Timing Chain cover Gasket
Valve Cover Gasket
is there anything else I should do whilst in these areas? Likewise is there anything I’ve listed there which is unnecessary that could easily be replaced later on in the event of failure?
