What are we using for rear diff fluid now that castol 75w140 is OOS??
Old Jul 25, 2022 | 05:12 PM
kenneyd's Avatar
poop
I went to to buy the factory recommended Limited Slip 75W-140 Full Synthetic Gear Oil https://amzn.to/3PVe6Ac but its out of stock everywhere for several months. not sure if they aren't making it anymore or what.
Does it just need to be API GL-5 or are their other requirements for the limited slip?
Old Jul 25, 2022 | 05:48 PM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
I believe as long as it's limited slip and the correct weight that is all you need.
I used the Liqui Moly in my '14 E63s:
https://www.fcpeuro.com/products/bmw...z4-83222282583
Old Jul 26, 2022 | 08:29 AM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
Valvoline makes a product with a LSD additive as well. I have used it in three of my vehicles with no issues.
Old Jul 26, 2022 | 11:06 AM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Mercedes Differential Oil SAE 75W-140 Motul Gear Competition 105779 001-989-52-03-10 001989520310 001 989 52 03 10 3374650011455 001.989.52.03.10 | Pelican Parts
Castrol - 001989520310 - Castrol SAF-XJ (75w-140) - 500mL (ecstuning.com)
Old Jul 26, 2022 | 11:55 AM
dustinN's Avatar
09E350, 07E63, 13CLS63
https://www.amazon.com/dp/B00C3JWPDG?psc=1&ref=ppx_yo2ov_dt_b_product_detail s
CASTROL GEAR OIL 75W140 SYNTRAX LONGLIFE - 558.00.97 - CASTROL - Content: 1,0 l
Can this one be used?
Edited: Never mind, it's for open differential cars.
Old Jul 27, 2022 | 01:32 PM
dustinN's Avatar
All the videos I found indicating that for LSD both wheels spin same direction, for Non-LSD wheels spin opposite direction. My wheels spin only one at a time. Spin one, the other stay still. Does it also mean that I have Non-LSD? I can't seem to find any video/article supports this.
Old Jul 27, 2022 | 01:34 PM
kenneyd's Avatar
poop
I found a few of the 0.5l castrol from the dealer from ebay https://www.ebay.com/itm/175037966160 pn 001 989 52 0310
Old Jul 27, 2022 | 01:41 PM
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
what are we putting that oil in
Old Jul 27, 2022 | 01:52 PM
Valvestud's Avatar
Hopefully the rear differential. This oil is for the LSD option 471.
Old Jul 27, 2022 | 02:09 PM
dustinN's Avatar
Did you check with your local dealer? Mine has those for $25/500ml bottle.
Old Jul 28, 2022 | 08:36 AM
MerchantM5arine's Avatar
2014 E63 S Wagon
FCP Euro has them at $20 each. https://www.fcpeuro.com/products/syn...castrol-1543c9
Old Jul 28, 2022 | 08:38 AM
kenneyd's Avatar
poop
Originally Posted by MerchantM5arine
Sweet, good to know there's options. I bought them from that eBay link, two for $30
Old Oct 20, 2022 | 08:12 AM
SilverE5588's Avatar
'15 E63S,'21 LCI M5
Going to pickup up some rear diff. fluid over the weekend . My dealer said the plugs dont have any gaskets. What type of ptfe or sealant can be used on the rear diff. drain plugs ? saw the GM pipe sealant with ptfe mentioned at one point .. Two 0.5Liter bottles covers it correct
Old Oct 20, 2022 | 12:15 PM
Valvestud's Avatar
When I look at the current approved oil spec 235.61, the only one listed is "Castrol Transmax Limited Slip LL 75W-140" Attached is the chart for the various oil specs.
Regards,
Joe
Old Oct 20, 2022 | 03:25 PM
ImolaSix's Avatar
2014 E63s AMG
You will need 3 (0.5 L) bottles of the 75W140 Castrol Transmax Limited Slip. I recently did mine and it took about 1.2-1.3L before it started coming out of the fill hole.
I personally didn't use any thread sealant as the threads are tapered to create a seal without the need for a crush washer or sealant. I have no leaks. You're welcome to use sealant if you prefer, I'm sure it wouldn't hurt.
Old Oct 21, 2022 | 11:19 AM
Same here, I've never used sealant on any of my rear diffs, it won't leak once you get it tightened.
I'd recommend picking up a bottle pump too, clearance is tight back there for the taller bottles that have a squeeze tube (which you may need to cut off to fit the pump) but it saves your hands a workout.
