Damping Valve Malfunction
No error codes on the dash, CEL or suspension related, but I scanned this (using iCarsoft MBII) because intermittently the suspension mode locks itself in Sport 1 and you can't go to Comfort or Sport 2. It did it on and off for a week, then was fine for a few weeks, and acted up again this morning.
I understand Sport 1 is the default for the rear air bags height-wise, but the 'right front' notation threw me off thinking maybe the issue is with the front strut and not the rear. Anyone run into similar problems, ideas on what I should/can check next without having STAR?
I actually keep it in Sport 1 most of the time anyway (so it could have been acting up more than I knew) but my wife who's 8 months pregnant and massively uncomfortable definitely notices when it's not in Comfort
As far as I know it's never switched back to normal during a drive, only after the car's been shut off and back on again later. So maybe it's the rear suspension not meeting some parameter when it releases air after you park it?
Complaint: AIRMATIC fault message in instrument cluster. Various fault codes in quick test possible, see listing of fault codes.
Cause: Electrical malfunction of the damping valves in the left or right shock absorber on the front or rear axle due to:
- Corrosion in the plug on the ADS module or in the control unit.
- Short circuit to ground or positive in the electrical actuation line of the ADS module
- Internal fault in the damping valves
Remedy:
1. Check the connector for corrosion, repair if necessary. Check the electrical line for short circuit to ground or positive, repair if necessary.
2. If the connectors and electrical lines are OK, replace the affected suspension strut.
Remedy:
I need to do my cross struts soon anyway so I'll get her on the lift and see what I find and report back!
