FYI OverFlow Reservoir Replacement
Its a MU25. My tip is since the bottle is trash, I use a hacksaw blade to cut the nipple off the tank half way and snap it off, with the bottle out of the car it was easy to remove the clamp from the hose and pull out the nipple. My five minutes took under an hr including walking time and chat session at the shop.. So if you are planning on doing this maintenance item please have a MU25 as a replacement just in-case.
But, it's mostly cause I don't have the proper tool for spring clamps and just use pliers, which don't always grab them properly
That is the reason I went back to the OE style. If it was metal it would have been a standard clamp for sure. Been working on lots of JDM and all are spring clamps and I never had an issue using them I always try to place them on the hose to match the imprint.
