2015 E63S Coolant expansion tank leak- DIY or shop job?
It seems common from my research but I cant seem to find any instructions for changing it.
DYI
do you know if I need to bleed the system after changing or do I just top up and let it run with the cap off for a few mins?
Maybe opening myself up here....but, for $350...sure, that for me is about two hours of billable time. I could easily hire someone to replace it...but, my father taught me to be a man and fix my own things. The way I see it, if some guy who is at work high most of the time can fix it...so can I. The only thing in life I have not figure out how to do well is finish drywall and drywall repairs....I guess you need to be high and not very bright when you do that. The rest....heck, half the fun of cars is tinkering and fixing them. Not long ago I put a new SAM in my other cars and decided to put all new head gaskets on it...just on a whim (C240).
So, yes. I have the 15 minutes and the brain power to replace a freaking coolant tank.
Mercedes Coolant/Antifreeze Pink - Genuine Mercedes 0009896807090109 | FCP Euro
1. You'll need to either siphon out coolant in the tank or do this at the same time of a coolant change.
2. Assuming you didn't do this at the same time as a full coolant swap, if there's concern of air getting in the system, you have two options to refill it: 1. You can use a vacuum fill method using the expensive coolant fill tool or 2. You can fill it and "burp" the air out of the system using the old school method of idling the car with the heat on at full blast while the car reaches operating temps. This will take no less than 25 minutes with these cars but works fine.
3. If you did do this at the same time as a coolant swap, refer to my 2nd note above.
Enjoy.
