M156 Longtube header Install: Tools and Tips?
Old Dec 6, 2022 | 03:47 PM
MTBSully's Avatar
2006 E55
About to tackle longtube headers on my 2010 E63 AMG. So far ive got:
  • OBX Longtube headers and Off road X pipe
  • OEM Gaskets
  • New OEM Studs and Nuts
  • OEM Bosch Alternator voltage regulator
The voltage regulator i am pretty sure is a "while you're in there" job. I may also do motor mounts since they should be easy to get to while the exhaust is out of the way. Any tips/tricks on this chassis? I've got an assortment of 11mm sockets and ratcheting wrenches. Any other tips?
Old Nov 29, 2024 | 06:00 PM
07ETreeFiddy's Avatar
(Daily)2007 E350 Base, (wkend)’10 E63
I’m considering doing this in my driveway with a QJ setup no lift. Seems moderately difficult, but definitely doable. Did you ever end up tackling them? If so, what would you have done differently? Also, if doing it over would you go with the parts that you used the first time?
