Ethanol Sensor installation
Old Mar 11, 2023 | 01:45 AM
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
Does any have any instructions or a DIY video on an ethanol sensor on a m157?
Im about to order one from Spool but wanted to see how hard it is to install
Old Mar 11, 2023 | 07:28 AM
Mojo20032004's Avatar
2014 E63S
I don't have any instructions on how to install, but I had my local eurocharged install mine for 150 bucks. Took them little more than 1hr
Old Mar 11, 2023 | 01:10 PM
bentz69's Avatar
'16 CLS63S
This is how I did mine. Kit comes with directions. It will tell you which wire to tap in that harness for power
Old Mar 12, 2023 | 01:13 PM
AMGfifty5's Avatar
perfect ty
Old Mar 21, 2023 | 03:19 PM
AMc450amg's Avatar
Mercedes Benz C450 AMG
Install instructions (Spool)
Mine didn't come with instructions but Spool did send a PDF upon request.
I do have a question for everyone installing the Spool Ethanol analyzer.
The instructions show the filter ahead ( upstream) of the analyzer . Does it matter which order they are connected?
Or is this just another case of my E63 OCD ?
Old Mar 22, 2023 | 01:51 AM
billvp218's Avatar
m157 SL63
if anyone in here is looking for some upgraded HPFPs, I have some used (<10k mile) Spool FX-150 that I can give you a deal on
Old Mar 22, 2023 | 03:23 AM
bentz69's Avatar
'16 CLS63S
Is the high pressure pump all you need to run full E85 or do you need the low pressure pump as well?
Old Mar 22, 2023 | 03:44 AM
billvp218's Avatar
m157 SL63
I don't know any m157 running pure e85, so I'm not sure. I think max power stock-turbo e-tunes are capped in the e30 range without HPFPs. Spool sells the low pressure pump kit separately.
Old Mar 22, 2023 | 07:30 PM
AMGfifty5's Avatar
I haven’t ordered yet. But if you decide to a DIY tutorial or post on YouTube thatd be great 😊
Old Mar 24, 2023 | 12:40 PM
CerBErusM113's Avatar
2015 CLS63 S AMG
I installed mine and it looked similar to @bentz69 's setup. I found the fuel pump fuse, pulled it, fired the car up and let it shut off once all the fuel in the lines were spent. After this I disconnected the fuel line's in the engine bay and just routed the fuel filter inline and then sent it to the methanol sensor and after the sensor it went to the fuel rail. Make sure to tighten the fittings firmly, after that plug in the fuel pump fuse, put the key to position 2 and let the fuel pump prime, check the schraeder valve at the fuel rail for pressure (carefully). After that give the car a start up. It may take a moment to crank but should fire up. Let it idle, make sure it sounds good and consistent, check for leaks and tighten fittings as appropriate. Then turn it off and work on wiring in the pump. (Someone else can write that part as I think I did a poor job on mine and need to redo it)
Also, I put my fuel filter prior to the analyzer so the analyzer would get the cleanest fuel and not gum up over time. I also want to make sure that it's not getting a different ethanol content reading than what is going into the engine.
Hope this helps!
Old Mar 24, 2023 | 01:33 PM
bentz69's Avatar
'16 CLS63S
Hope this helps!
The filter will not change the ethanol content that the sensor reads. Nevertheless, I have yet to see someone open this filter up after xxxxx amount of miles to see what it has filtered. Im at 25000 miles since the install always running e50. Kind of curious now...
Old Mar 24, 2023 | 01:37 PM
billvp218's Avatar
m157 SL63
I opened mine up after 2 years but only 8k miles, and there was no gunk or build-up. I replaced the faulty Spool fuel filter shortly after it was installed with one from ForeInnovations.
Old Mar 24, 2023 | 11:28 PM
bentz69's Avatar
'16 CLS63S
Why was your spool filter faulty?
I ran 100% e85 on my w204 c63 for about 75000 miles but I did not have a secondary fuel filter like the spool one we are using now. I also installed new injectors at the same time I installed the e85 kit on the c63. After 75000 miles the injectors were in pretty bad shape as far as being gummed up. I was also using redline fuel cleaner every 10k miles.
I use redline fuel cleaner every 5k miles now in the cls63 (honestly not sure if it helps) but Im still concerned about the injectors. Although, running e40-e50 is not as harsh as pure e85 because of the detergents in top tier 93 gas like BP and Shell since we are mixing. Only time will tell...
Old Mar 25, 2023 | 08:42 PM
billvp218's Avatar
m157 SL63
I had the full Spool kit installed on my car by EC HTX. A few days after getting it back, as I was getting ready to leave from home I smelled a pretty strong ethanol smell. I opened the hood and saw what's in the below file. I took a quick vid and shut the car off.
Apparently Spool used some seals in their (at least early) m157 ethanol filters which were not suitable for use with ethanol , and that caused them to fail over a short period of time. What was wrong wasn't known at that time, but this happened to several people. Spool did end up eventually giving me a refund on the filter, but that seemed pretty dangerous.
I started out running full e85, but later moved to lower blends - I had an apparent tuning issue which had me running lean, and reducing e-content was one of the things I did to try to fix the lean issue (it didn't work beyond a run or two, the tune then dropped fueling to get me back to lean ). I did have an injector which failed, and I ended up having them all replaced to reset the clock. My car has only 35k miles on it.
File Type: wmv
Old Mar 26, 2023 | 01:11 PM
Scott Gerhardt's Avatar
2014 E63 AMG
E60 is the max stock pumps can handle.
I also removed my spool sensor. It leaked twice dumping fuel on a hot engine. After the second time, I was pretty much done using spool products. And Spool did the original install and warranty fix. After the second failure, I pulled it out myself.
Old Mar 27, 2023 | 02:39 AM
billvp218's Avatar
m157 SL63
What power level are you referring to with e60? I'm talking about 700whp or so, where some people have had issues trying e40 and had to drop it. Maybe some work, but e30 is more common for those levels on stock pumps. I'd actually be surprised if much higher than stockish 550whp could be supported at e60 on stock pumps.
Old Mar 27, 2023 | 10:28 PM
2014 E63 AMG
Several people have had eurocharged tunes that got in the e50-e60 range. BrutusTX (spelling) is one of the first to do so, he ended up backing down to e50 from e60. I have also seen cars that had issues with just e30.
As for AWHP, it was just over 700. I can’t find my dyno printouts, I just moved so it may have been cleaned out before, lost during or lost after the move. I am about to do my taxes, can’t wait to see what else was lost!
From what I was told, there was not a huge difference in hp gains between e40 and e60.
Old Mar 29, 2023 | 03:34 PM
AMGfifty5's Avatar
Any there any other e85 sensor kits compatible with our cars besides spool?
is the filter necessary?
