E63 Suspension level sensor values
Old Mar 21, 2023 | 06:32 PM
SilverE5588's Avatar
'15 E63S,'21 LCI M5
So long story short , hit a pothole a few weeks ago, no damage done besides needing an alignment . Got an airmatic light not long after , tracked down to a misadjusted l/f level sensor (mounting ubolt was semi loose) sensor moved on the control arm. Ubolt is stretched and suspect the bracket is bent . After resecuring the sensor the airmatic light hasnt returned, but the rear sits a little high now .
Pics of the specs are on a tilted garage floor & the rear was raised up quite a bit . Rear looks in sync. but unsure on the front sensors , looks like l/f is out of whack for sure 1 vs 27mm eek. Any insight and or the range they should be in. Looks like replacement of l/f sensor is in order.
