m278 oil change/ Ceratec Question
anyways trying to just keep it going for now because repair or new old motor swap doesnt make financial sense
so the last shop that did oil change uses LM, and also uses ceratec bottle or 2. Their last invoice doesnt say it was used but when i drained the oil I was wondering could ceratec cause the oil to look like this.... or are we well beyond just bad turbos.cams on this motor.
This what came out.
I hope you unplugged the oil solenoid with 155k miles on the clock. Should clean up that chatter with more oil flow, even at idle.
I had the car on a 4 post lift so it would have been hard to access the very front. I need to do it on my e63 also.
I havent followed that thread for a while need to catch up on it and probably order two dummie connectors to plug them
