Aftermarket wheels 5x112 66.5mm hub, fitment to W212 E63 Hub
Old Jan 8, 2025 | 07:45 PM
alpinaturbo's Avatar
E63 Wagon
Gents
considering aftermarket wheels, concerned - given some discussions on spacers, and different fit on front and rear due to a chamfer on hub.
For wheel fitment, that is 5x112, with 66.5mm hub, anything else to worry about?
https://www.evasivemotorsports.com/s...sSDF2S8cPiWsys
Yes, +50mm offset, so it fits rear as is and I add hubcentric 20mm spacer in front.
To run 285/30x19 all around. They look OEM, so low key look. Are lighter then OEM substantially.
After square setup to rotate, added front end grip, and less rotational mass.
Incidentally what are best 20mm spacers for front please, that fit our "special hub chamfer"?
Thank you for last minute sanity check.
