Noisy front end in 2014 E63…looking to diagnose.
if they're shot I would get new Michelin ps5's summers first since you need new tires anyway (in that case) and then drive and re assess
there is a discussion here about issues with the steering rack causing slop with routine driving
https://mbworld.org/forums/w212-amg/...g-noise-2.html
Wheel bearings, event mounts and propeller shaft hangar bearing have been documented as causing noise while driving at speed,
Also unclear if your steering perception is real or imagined and if real, then unclear if it's a connected issue or separate issue
and... tires and alignment could solve both the steering and road noise
any accidents recently or in its history?
audio clips?
