Wheel spacers
Thank you!
Mandarin (07-12-2018)
2018 E43 | 2017 GLS450 | 2004 CLK 500
I'm not sure if it's the same for your 63, but the H&R part # for my 18 e43:
3055665SW (15mm). Yeah you'll need to find another vehicle that uses the same part # and then reference the 12mm spacer. Also the SW just means black.
I'm not sure why H&R doesn't include some of the w213 models. I think when I looked this up last year I just referenced the 2018 E coupe and took a chance with my order and it worked.
Side note: I purchased longer black titanium bolts and some of them on one wheel started to show thread wear. Seems to be a known issue with the softer metal threaded into a harder metal, but since it's only one wheel I suspect the mechanic threaded them on using the air wrench. But my spacers are off now until I find the right steel bolts just in case.
Ed99 (06-04-2023)
Ed99 (06-04-2023)
#34
go fast grocery getter wagon
#35
#37
#38
bobblehead (06-08-2023)
#39
15mm spacer = 63mm bolt - cool they have that size.
12mm spacer - 60mm bolt. Cool they have that size too.
bobblehead (06-09-2023)
