Mystery Anti Freeze Smell coming from under the hood of my car
Old Mar 14, 2018 | 10:38 PM
2012 merc amg's Avatar
2018 S560
Every time after I drive my Wagon I notice a antifreeze smell coming from the engine compartment. Strange thing is I don't have any leaks underneath the car, the overflow compartment is full (actually looks a little over full), maybe overfilled a little from the factory as I did not touch it. But strange. No apparent leaks, nothing seems to disappearing from the overflow tank. Anyone else notice a antifreeze smell from the engine compartment? I really don't feel like a trip to the dealer until the 10K oil change which is 5500 miles away. If it appeared I was loosing antifreeze I'd be really worried. Does not run hot at all or anything. Every time I look at the gauge its running 174 or so. These cars seem to run cooler than most, definitely have a lower degree thermostat than most cars. I guess there must just be a tiny seep that going on something hot on the engine. I guess I should probably pull of the cover and get a look at it. In a month and half I drive 1400 miles back up north from Florida and was not planning on getting the oil changed until I'm up there sometime this summer. It's definitely an antifreeze smell though. You'd think if it was a hose fitting on one of the intercoolers or the radiator I'd have spots of coolant underneath the car.
Old Mar 15, 2018 | 12:42 PM
jdhertz11's Avatar
G
Our last C300 and current GLC300 smell(ed) like coolant. I gave up after a few trips to the dealer with no results. Maybe they all burn coolant like they burn oil!
Old Mar 15, 2018 | 01:47 PM
cpais's Avatar
E55, GMC Suburban, F430 matchbox, Caddooo DTS
If you had it tuned it could be from when the ECU was removed from the car. The ECU's in these cars are water cooled so they have anti freeze running through them. If someone removed the ECU they could have spilled anti-freeze when it was removed and that is what you would be smelling. It won't end up on the ground if that is where it leaked.
Old Mar 18, 2018 | 09:52 PM
2018 S560
That makes sense that sense that it might be the ECU Seeping a little bit. I'll get it checked out at the 10000 mile oil change. My ECU has never been removed as I'm running a stock tune. Thanks for the info, glad I made this post.
