Need to reduce front end negative camber.
Old Jul 5, 2018 | 05:12 PM
DougRTWMotoring's Avatar
2008 E350
Once we get those bushings in I expect a "Shout Out"!!
Old Jul 5, 2018 | 06:03 PM
ronin amg's Avatar
2024 EQE AMG SUV . 2021 GLE AMG 63s Coupe
As soon as we find out they work or you will be getting a very different shout out...
Old Jul 5, 2018 | 06:30 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Originally Posted by ronin amg
I'll be ordering the kit today...
<snip>...</snip>
Cold tire pressure 51 psi.front 50 psi.rear... I'll be testing a set of 305/30/20 on the rear today..
51/50 psi, isn't that the pressure for doing like 150+ MPH driving? How is the ride with the pressure set that high?
I had mine set to 41/36 or there about and that seemed fine. But I noticed that when picked the car up from service after they replaced the left rear strut and fiddled with the anti-sway bar that the tires were set to 41 all the way around.
That would be fine if I had passengers or some junk in the trunk, but mostly it's just me tooling to work and back.
Old Jul 5, 2018 | 07:34 PM
ronin amg's Avatar
My car rides fine.
Stock calls for 51,49 and running on lower pressures will make the soft sidewalls even softer in the corners... If they set your car at 41psi. all around they should not be working at a Mercedes dealership.
Old Jul 5, 2018 | 07:53 PM
Vic55's Avatar
Administrator
51/49 is full laden with 5 people and 4 suitcases... and speeds up 180 mph...
the inside of the gas cap denotes the suggested psi's
Old Jul 5, 2018 | 07:58 PM
ronin amg's Avatar
Nice if you are an old lady but us old men like a car that corners precisely and body roll due to sidewall squirm is for those damn kids....
If you are lowered and run the lower air pressure check your inside tire before you need a call for a flatbed tow..
Old Jul 5, 2018 | 08:02 PM
  #32
Vic55's Avatar
Administrator
I check religiously--- so far so great
Old Jul 5, 2018 | 08:07 PM
  #33
ronin amg's Avatar
I did run a lower pressure at first but I could feel the difference for the better in the canyons with the higher speed settings.
Ya never know when ya feel the need to out pace a Ducati from time to time..
Old Jul 5, 2018 | 08:28 PM
  #34
Clk63blkseries's Avatar
2018 E63 S (white wagon), 2016 Viper ACR Extreme, 2005 Porsche GT3 Cup race car,2020 GLE
Ohhhhh inside makes more sense with all the negative camber and front weight. You may want pull out a little camber especially since you have wider wheels up front. I still think you have toe out and the inside is scrubbing a little. Maybe it moved or they were a little off on there reads
Curious to see what the numbers come up at
Old Jul 5, 2018 | 11:06 PM
  #35
Wolfman's Avatar
Super Moderator
Off-topic question. Do you have any inner tire wear due to lowering ? I was running on snows for a long time due to the lousy weather. A bit of inner wear on the fronts but normal in the rears... First time I haven't done an alignment after lowering... Am actually surprised how unaffected the car is.
Old Jul 6, 2018 | 10:31 AM
  #36
Vic55's Avatar
Administrator
Im on the PS4's with even wear the last time it was on the rack (a week ago) but Im also not racking up a ton of miles but even after 2200 and being lowered from mile 125 or so I would see wear.
Now I am seeing alot of tq wear in the rears LOL.
Old Jul 6, 2018 | 01:42 PM
  #37
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Related to tire wear, anyone else getting new tire purchase reminders from their dealer or Mercedes telling them its time for new tires?
I have a bit over 7500 miles and my tires are still in pretty good shape. Wondering how hard Mercedes thinks I am driving this car?
I'm sort of half hoping they'll wear out soon so that I can get rid of the Pirellis and get on PS4s, but for now the Pirellis are OK for my daily 5 mile commute . . .
Old Jul 6, 2018 | 02:56 PM
  #38
ronin amg's Avatar
I was at 5,200 mi. and the wear was fine except for the fronts..
The new set of PS4s 285/305 should grip better and last longer without slowing down..We'll see.
Old Jul 6, 2018 | 03:27 PM
  #39
Wolfman's Avatar
Super Moderator
The best kind of tire wear
We drove over 5k miles on the snows, lowered, so the wear is minimal...
Old Jul 12, 2018 | 05:52 PM
  #40
ronin amg's Avatar
Originally Posted by K-Mac
Have attached "Quick Reference" sheet!
C213 E635 AMG Front Camber & Caster adjuster kit is #502816 K $480 (3rd entry down - below W205).
While rear kit Camber (and extra Toe) is #502226K $480
Both F / R kits provide up to 4 times adjustment of the one offset position fluted bolts and is precise single wrench adjustment.
Rear Multi link uprated bushing kit for C213 #502628 K $480 Kevin
As I expected from the website for these bushings, the bushings sent are the wrong size and I've wasted my time...
Old Jul 17, 2018 | 12:42 PM
  #41
ronin amg's Avatar
So the "right" bushings are being installed [hopefully] today and we'll see how this goes.. I gotta say quick shipping is a plus..
Old Jul 17, 2018 | 12:55 PM
  #42
2008 E350
Maybe....
Old Jul 17, 2018 | 06:01 PM
  #43
ronin amg's Avatar
Well it all looks good now thanks to Doug at Ron's Tire and Wheel in North Hollywood Ca.
Old Jul 17, 2018 | 06:20 PM
  #44
Mandarin's Avatar
e63s
Actual car's pictures? I also don't like how front wheels look like and wanna change camber too.
Old Jul 17, 2018 | 06:49 PM
  #45
ronin amg's Avatar
Not really all that different to be honest but going from a -2.7 to a -1.8 will do the job for me.
I'm getting a set of Zito wheels 10x20 and 11x20, after tomorrow's test fitment I will be posting pictures...
Old Jul 17, 2018 | 07:33 PM
  #46
2008 E350
SERIOUSLY?????
Old Jul 18, 2018 | 08:16 PM
  #47
ronin amg's Avatar
SERIOUSLY?????
Yeah they are doing a set with custom offsets for me.
Here is a rendering to get an idea,,
Old Jul 19, 2018 | 12:35 PM
  #48
Dagger9903's Avatar
Nissan
damn, that color combo looks awesome.
