How to change right side of progressive display?
Old Dec 7, 2018 | 12:48 AM
etoosh's Avatar
E63s
I can change the left side of the progressive display, but how do I change the right side?
Old Dec 7, 2018 | 11:36 AM
Dagger9903's Avatar
Nissan
Left thumb pad, swipe right, the right side of the display should be outlined/highlighted. In some modes you can swipe up/down and it will change the screen. If you press the "home" button on the left side of the steering wheel, the same options for displays (e.g. radio, media, nav, AMG, etc.) as the left side should come up as well.
Old Dec 7, 2018 | 12:15 PM
etoosh's Avatar
E63s
So there isn't a way to display media on the right hand side? You can only use the options they have pre-selected? I can change the left hand side to mobile, etc - I thought the behavior would be the same on the right hand side.
Old Dec 7, 2018 | 01:17 PM
Dagger9903's Avatar
Nissan
I can't remember, but I believe it is possible. If you swipe right on the left thumbpad, then hit the home bottom on the right hand side of the steering wheel (to the top left of the touch pad), that should give you the option to show a different set of screen on the right, including Media.
Old Dec 7, 2018 | 03:29 PM
honeybadger15's Avatar
'19 E63s
I think you're limited on what you can change on the right side of the display for Progressive. Using the left thumb pad on the steering wheel, scroll to the right side, then scroll up/down to change the display.
I kept trying to see if I could change it to something more useful after getting a little tired of staring at my 12mpg . Moved onto the Boost, HP, Torque display for the right side.
Old Dec 7, 2018 | 03:51 PM
Dagger9903's Avatar
Nissan
Weird, I could swear I was on progressive with radio on the left and nav on the right. Maybe I was in sport...
Old Dec 7, 2018 | 04:31 PM
'19 E63s
You probably were - you can select Nav as one of the options for the right side.
