Engine and Transmission Temps?
Old Dec 18, 2018 | 10:01 AM
X166's Avatar
2013 GL550
I noticed the cooling fan blowing loudly during my drive. Engine temp around 208-212 and transmission temp around 238-240.
Is this normal operating temp for this car? Was after a 50 mile drive in traffic—about 1.5 hour drive time.
Old Dec 18, 2018 | 10:10 AM
X166's Avatar
2013 GL550
Also, now that I think of it, after my 50 commutes, I have noticed some liquid under the car near the front. Very small / tiny puddle. Liquid has no smell. Viscosity like water. Clear. Is it just condensation of some sort?
No messages under Service menu. Coolant gauge is smack in the middle of the range.
Thoughts? Thanks in advance.
Old Dec 18, 2018 | 10:36 AM
Ralcbah's Avatar
2018 E63S
No, not normal man. You have an inter-cooler leak somewhere is a likely diagnosis. I was having high transmission temps as well for a bit, under easy easy driving....tech said I was missing half the fluid from the intercooler. Take it in to be looked at. Don't drive it too hard at those temps.
...even under very spirited driving, trans temp doesn't get over 190ish
Old Dec 18, 2018 | 10:51 AM
X166's Avatar
2013 GL550
Uh...can I even drive to the dealer...? It’s 50 miles away..
Old Dec 18, 2018 | 10:55 AM
X166's Avatar
2013 GL550
How long did the repair take for you?
Old Dec 18, 2018 | 10:57 AM
Ralcbah's Avatar
2018 E63S
Call your tech and ask them what to do...I'm not qualified to answer that, unfortunately. I did drive mine for a bit with no issues...just kept it easy and in comfort mode. Trans temps higher than that will break down the trans oil and you'll lose lubrication. At what temp that happens, I don't really know.
Old Dec 18, 2018 | 10:58 AM
Ralcbah's Avatar
2018 E63S
It was a quick one. I believe they added fluid and changed out a pump.
Old Dec 18, 2018 | 11:00 AM
X166's Avatar
2013 GL550
Will call him and follow advice. Thanks.
Is it a typcially stocked part? Just curious if we’re talking 1-2 days or 1 week.
Old Dec 18, 2018 | 11:02 AM
Ralcbah's Avatar
2018 E63S
Ah. Yes, was stocked...1 day deal
Old Dec 18, 2018 | 11:20 AM
X166's Avatar
2013 GL550
Thanks so much! I have appointment today and will report back in case anyone else also has similar issues.
Old Dec 18, 2018 | 12:15 PM
78degrees's Avatar
2018 E63S
My guess is condensation from the air conditioning.. They wouldn't use water without coolant in any system in a car.
Old Dec 18, 2018 | 12:54 PM
jkob5's Avatar
19 E63s
trans temps way too high.
Old Dec 18, 2018 | 04:53 PM
X166's Avatar
2013 GL550
I’m at the dealer and they are checking the car for a leak. Was it the Auxiliary Cooling Pump you replaced? I found another thread where that was the issue for someone.
Old Dec 18, 2018 | 05:11 PM
Ralcbah's Avatar
2018 E63S
I don't know, unfortunately. Heard from my guy that fluid was missing and a pump was bad...that's all I got bud.
Old Dec 18, 2018 | 05:23 PM
X166's Avatar
2013 GL550
No worries—thanks a lot for the advice today!
Old Dec 18, 2018 | 06:02 PM
X166's Avatar
2013 GL550
Well...rock went through lower front intercooler...ugh.
Old Dec 18, 2018 | 06:20 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Oh, that sucks. Any idea how large it was? Wondering if the Zunsport guards would have done the trick.
I keep saying I'm going to get around to it, but I really need to either get off the dime and build a set or just go ahead and pick up a set of the Zunsports.
That's at least three punctures by my count.
Old Dec 18, 2018 | 06:31 PM
X166's Avatar
2013 GL550
Thanks. Anyone here have any luck getting MB to cover any part of this repair? Insane. I walked around the showroom and every car has some sort of protection, however flimsy.
