Windows Rattle After Tint
Old Jan 10, 2019 | 11:37 PM
wdimagineer's Avatar
E 53 Wagon
As the subject says, my windows now rattle after I had window tint installed. My car has the acoustic comfort package. The tint installed is Llumar Pinnacle ceramic. If I lower the windows slightly, the noises go away.
The car is due for the rear differential service, and I will likely bring it up to the service department. I’m curious if others have had similar issues?
Old Jan 10, 2019 | 11:43 PM
dav461's Avatar
GTR
did they took out window for tint ?
how cold is where you are ?
Old Jan 11, 2019 | 01:47 PM
E 53 Wagon
They did not remove anything to tint. It has been chilly here.
Old Jan 11, 2019 | 04:01 PM
PeterUbers's Avatar
It's likely coincidental if it's a rattle .. if the material is rubbing against the Benz window track/socket that is a tint problem
Old Jan 11, 2019 | 04:29 PM
bobblehead's Avatar
go fast grocery getter wagon
Is this on driver side window ? JUst make sure the top part of the door trim is not loose
Old Jan 11, 2019 | 06:37 PM
Tirgoman's Avatar
2023 AMG EQE 53
A good tinter today does not remove the window or door trim panel when they apply the tint so I doubt the tint is causing the rattle. Have you gone back to the shop? If it goes away when you slightly lower the window that's a clue but first stop is back to the installer. Now if the deal was the installer that's even easier because it's one stop. However if an outside shop did the tinting then the dealer is going to place the blame on them unfortunately.
