A weird message
And make sure you show them the pic and don't take no for an answer and neither have them fob you off...
these cars need the oil changed in the rear diff @ 2000 miles and every 30K after that. (page 11 in your AMG supplement).
I would start with having that done. It isn't covered under warranty unless you have the extra maintenance. $280. I don't remember if an additional issue was found at the dealer (and am not home this weekend to check the service sheet) but I would definitely take it in. Mine hasn't lit up with that error since.
Here is the MB internal document code for this error: LI35.41-P-062294 it is a known issue. Hope this helps.
My car will be due for the initial diff oil change soon. I'll ask about it then.
.BTW, the diff error was the "scariest," suggesting I pull over and have the car towed.
