TPMS for aftermarket/2nd set of wheels
Hi all,
I got a new set of wheels and unfortunately sensors that I bought doesn't work, I tried to do all steps from google and went to the shop to re-learn them, just doesn't work. They are 433MHz.
So could you guys share what sensors are you using and where you bought them for your set of aftermarket wheels or just 2nd set of wheels? I would really appreciate that. Thanks.
www.tpms.com
H003577SET BMW, Mercedes Benz, Rolls Royce Huf TPMS Sensor Set (Silver Valve Stem) $139.92
go fast grocery getter wagon
could they be defective and you can return them for exchange or refund ?
I bought MB OE part.
https://www.mboemparts.com/oem-parts...sor-0009052102
https://www.mbpartsworld.com/oem-par...sor-0009052102
Mandarin (03-05-2019)
www.tpms.com
I got them from oreilly and they are Schrader sensors
Service tool can see them but does show "no proper equipment" while the service guy was trying to read them, but they (tire shop) did not have models after 2015 in their tool, but I don't think there is any difference. As far as I understood from reading a lot of information system should recognize them by itself after a few minutes drive, but my cluster tells me "tpms system is inoperative no wheel sensors".
TireRack sells the same Huf sensors for W213 under p/n S207: https://www.tirerack.com/tpms/detail...810&S207_Qty=4
Restart you TPMS from screen menu and after 5-10min they will register by themself.
Tire rack sensors don't fit my wheels and I've returned them )
I do not see how we can help then. There are three choices: OEM, Huf or Schrader. Tpms.com and Tire Rack both know what they are doing.
https://www.tpms.com/2018_Mercedes_B...PMS_s/9026.htm
You are probably right, but when I was buying them I went to the store and said: "I need sensors for 2018 W213 e63". Seems like not enough for those people who are working there. The lesson is learned, will never buy anything from local parts store anymore.
Thank you for your help.
https://www.tpms.com/Schrader_EZ_Sen...ezc8238mbz.htm
Based on above picture looks like OEM are made by Schrader.
I am using HUF sensors on my '19 E450 (identical sensors to E63) for 19" OEM wheels, purchased at tpms.com link for which, with p/n, I provided above. I also stated that TireRack sells identical HUF sensors (for a bit more) which confirms that they are the correct sensors for W213.
I was told by the MB peeps the dash temperature is for brakes and at a track day I was seeing temps over 220F which I can’t imagine tires would be too happy about?
