How big are the stock turbos and how much boost do they run?
This is a BorgWarner part (their part number for it is 18509880005)
I see the part listed here; https://www.turbomarkt.de/Turbolader...der-476-560-PS
I was wondering if anybody knew the size of the turbos (the housing, the impellers, blah blah blah) and how much boost the stock map runs.
Compressor Wheel: 56mm OD / 41.7mm inducer
Turbine Wheel: 50mm OD / 44.5mm exducer
Turbine housing A/R: .57
What are your thoughts on throwing something like this on our cars: https://www.precisionturbo.net/Stree...PT5862-CEA/634 ?
I just need to figure out how to get compatible M177 brackets/housing, yeah?
So you are saying you can upgrade your turbos but not re-tune your car (aka ECU requests same amount of boost) and make more power over stock? or does ECU calculate flow and pull back the amount of boost requested?
