Adding oil in between oil changes
I'm not sure if driving style is a factor in increased consumption or not, but let's just say that... my engine sees some mild abuse.
I got my last oil change at 10k miles. I'm at like 16k now.
I received a message that engine oil was low, telling me to put a quart in.
I put a quart in (5W-40 from Mercedes if anybody is wondering), then went to the Measure Engine Oil level menu. That screen (not the message) said to add 2 quarts after I had already put a quart in.
I put another quart in, and it *still* says to add 2 quarts... Any advice? I saw it say "Measuring engine oil level" when I refresh the screen/powercycled the car. What is a normal amount of oil to have to add in between oil changes?
I drove the car around a bit to see if the oil would heat up/expand and change the measurement level but I don't think it made much of a difference.
adding 2 quarts may normally suggest you are at the "min" to start off and to reach the "max", that 2 quarts should be plenty enough, IMO.
For mine, I tend to add just 1 quart. The refreshed message would indicate my oil level would be 1 notch below "max" which I am okay with.
I'd be questioning the sensor or software at this point and schedule a visit with the dealer as I'd be worried about it being overfilled at this point.
that means i burnt roughly 2 quarts of oil in 6k miles of hard driving? not bad i guess. that’s a 3-6 month window so... right in life with 0.5 - 1 quart a month?
i added oil at 9am EST today, and it took until 2pm to update...
Chevy states that is OK I wonder what MB says is OK.
but that is limit less miles and they take a look at it.
Keep an eye on oil level for sure... or maybe drive in wimpy mode for 3000 miles to see if it burns less.
If I had a leak... would I notice it visually/physically somewhere or could it be burning internally at an excessing rate without me noticing? I don't personally think I have a leak, but your advice is good nonetheless.
