E63s from Munich
Old Oct 1, 2019 | 06:36 PM
  #51
CALBenzo's Avatar
'18 E63S AMG
I was able to fully pull off the bottom cover, but I was able to attempt removal of the tip through the rear opening. I was able to move the cover far enough to the side, along with masking tape on the cover, without touching the tip. However, as you mentioned, the bottom of the diffuser would require some significant stretching to remove and install the new tip. It was significant enough that I didn't want to break the diffuser so I stopped. Oh well, I will have to have the dealership, or a body shop, install the tips.
Thanks for the suggestions anyway!
Old Oct 2, 2019 | 07:51 AM
  #52
E63S.Muc's Avatar
E63s W213
No problem. Ye its a good stretch but works without any breaking . Its ABS plastic. Dealership/Workshop has to remove the full exhaust System to swap them. Should not be a problem. Glad you like the non S tips as well. Can you send me some pictures of the tips? i used black enamel on mine.
You bought the Night Package ones?
Old Oct 2, 2019 | 11:28 AM
  #53
nw66's Avatar
E63S 4MATIC 213
Was gonna say mine has night pack so already black! good work
Old Oct 2, 2019 | 05:50 PM
  #54
E63S.Muc's Avatar
E63s W213
Ye got Night Pack as well. And the non S tips were black also. Just didnt like the chrome black finish so i got black enamel on top.
Old Oct 3, 2019 | 08:02 AM
  #55
nw66's Avatar
E63S 4MATIC 213
Yes your car looks pretty much the same as mine from factory! good choice! keep up the good work
Old Oct 3, 2019 | 09:19 AM
  #56
E63S.Muc's Avatar
E63s W213
Thanks. Last thing are the door handles. Thank god they are so easy to remove.
Old Oct 3, 2019 | 11:33 AM
  #57
E63Wagen's Avatar
2020 E63S Wagon, 2007 335i convertible (tuned to 400hp), 2011 Audi A4 Avant
Has anybody tried using a "sealant" on their wheels to help prevent brake dust from adhering? Wondering if the sealants out there would still work (retaining the matte look) on the matte finish wheels that are an option on the car, like the ones nw66 has in the pics above.
Old Oct 3, 2019 | 11:58 AM
  #58
doba_s's Avatar
M3
I have used ceramic coating and it works amazing! The matte finish always stays like new and no brake dust and super easy to clean too.
Old Oct 3, 2019 | 12:10 PM
  #59
E63Wagen's Avatar
Good to hear! Any recommendation on a specific ceramic brand?
Old Oct 5, 2019 | 05:22 PM
  #60
E63S.Muc's Avatar
E63s W213
Yes. Use GYEON RIM its pretty awesome.
Old Oct 5, 2019 | 05:50 PM
  #61
MuffinFlavored's Avatar
2018 W213 E 63 S AMG Sedan
how hard is this to do?
do you use the iron spray that makes brake dust purple? i feel like that stuff affects wheel weights and eats the iron off of them
Old Oct 5, 2019 | 05:53 PM
  #62
E63S.Muc's Avatar
E63s W213
my wheel weights are always black never had an issue. You clean the wheels properly. Apply the coating and follow the instructions. Its really easy. I recommend to remove the wheels from the car for a proper application. There are many youtube videos on how to.
You just need water or some foam to clean them after the coating.
Old Oct 5, 2019 | 05:54 PM
  #63
that is *******g amazing
did you ceramic coat your entire car for easy washing?
  #64
E63S.Muc's Avatar
E63s W213
Yes see pictures above about the process. This is the best Coating so far. Gyeon Duraflex. I can drive through rain and it doenst matter at all. Not even wipers need.
Old Oct 5, 2019 | 05:55 PM
  #65
how much did you pay for whole car coated?
Old Oct 5, 2019 | 05:56 PM
  #66
E63S.Muc's Avatar
E63s W213
i wanted 99% correction so it was more than 5 days of work. Around 2000$
Old Oct 5, 2019 | 05:57 PM
  #67
5 days of work for paint correction and coating, how long would just coating the car have taken
Old Oct 5, 2019 | 06:03 PM
  #68
E63S.Muc's Avatar
E63s W213
1 day.
Old Oct 6, 2019 | 11:30 AM
  #69
doba_s's Avatar
M3
The proper way is to use decon on the car (the stuff that turns purple after it reacts with any contamination on your paint), wash it off, clay bar it, do paint correction then ceramic coating.
If you just do coating without other steps it’s not effective as it can’t bond to the paint properly.
Old Oct 6, 2019 | 11:31 AM
  #70
E63S.Muc's Avatar
E63s W213
all those steps were done properly. Clay bar, decon everything. Thats why it took so long But if you just want the coating you can do those steps in 1 day or max 2 days. But you are right i would not just coat the car.
Old Oct 6, 2019 | 11:50 AM
  #71
doba_s's Avatar
M3
oh yeah when you say 5 days I have no doubt whoever did it got it down the right way. I was just referring to if you can do “just the coating” and just wanted to paint it out that you have to do the prep work first. Coating by itself goes pretty quickly.
My car is selenite gray magno so cant do clay or polishing ... Going to use Kamikaze coating which seems to work well with matte finish paint.
Old Oct 6, 2019 | 12:08 PM
  #72
E63S.Muc's Avatar
E63s W213
Ye Kamikaze is good. Maybe Check Gyeon Matte. Their products are really lovely. Coated all windows with Gyeon View as well. No wipers need. Used those products 7 years on my previous car. Held up really well up to the 5th year.
Old Oct 6, 2019 | 12:57 PM
  #73
what is a good decon product? is it ok to use for regular details/washes if you aren’t coating?
Old Oct 6, 2019 | 01:00 PM
  #74
E63S.Muc's Avatar
E63s W213
this a long story. To decon use Gyeon Iron and Gyeon Tar or similiar products. Youtube how to 2 buckets grit guard wash a car . if you want to do it properly.
Old Oct 6, 2019 | 02:30 PM
  #75
doba_s's Avatar
M3
Once you coat your car you technically don't need to decon ... all you need to do is get a shampoo that doesn't strip coating and you can buy a lot of quick detailing sprays that are silica based specifically for coated cars. Carpro, Chemical Guys, and other companies have all that ...
