Ready Light on Display
I have noticed though that the auto stop-start feature on my car does not work most of the time. This is because my drives are typically ~4 miles to work and back each day. The battery apparently does not get enough of a charge to feel it's ready for the extra stop/start draw. That and I don't think the engine is warmed to the point where it's ready to enable the mode.
If I put the car on a trickle charger over night or go for a longer drive as I did this weekend, then the stop/start functionality starts working again. But as noted above, still haven't observed that indicator in the Progressive display mode.
Next car will randomly flash 'driving aid not available' and slow down abruptly. Don't get to that point as I did. I went to dealer and told them to replace the battery because car should perform to technical specs and after some arguments they did it.
Probably I will have to do it again in a year but it's ok with me.
Right now I run a trickle charger to the cigarette lighter in my 911 once or twice a month overnight...easy as anything...no need to run a lead.
Regardless, the car shuts itself down after a while if you leave the car still on as a safety feature so you don’t carbon monoxide poison yourself in an enclosed space such as a garage. I think it uses driver seat weight to determine this. The 53’s can shut down the engine for long periods of time at a stop (around 10 mins) because it has the big 48V battery to run all the accessories including AC.
