W213 E63S Wagon wheels, offset, and lowering
Old Aug 12, 2019 | 06:18 PM
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
Question W213 E63S Wagon wheels, offset, and lowering
After doing some Googling both here and on the net I've worked up a list of specs. I'm not positive they're correct so please chime in if you know otherwise
Front OEM
Tire: 265/35R20
Wheel: 9.5x20ET25
Rear OEM
Tire: 295/30R20
Wheel: 10x20ET55
Both:
Centerbore: 66.6mm
Lug thread size: M14 x1.5
Bolt pattern: 5x112
Common mods:
Front 15mm spacer
Rear: 12mm spacer
Custom Wheel size (sans spacers):
Front 9.5x20ET10
Rear 10x20ET43
Lowering: 20mm to 37mm (Max).
Questions:
With spacers/custom wheels (OEM widths) and a 20mm drop how is driveability and tire wear affected? Assume alignment is put back to stock specs. I know scrub radius changes but don't know enough to say if that is a good, bad, or indifferent change.
Last edited by TugboatBill; Oct 16, 2019 at 04:05 PM. Reason: fix bolt thread error
Old Aug 12, 2019 | 06:54 PM
ronin amg's Avatar
2024 EQE AMG SUV . 2021 GLE AMG 63s Coupe
Rears are 295/30/20
If you lower your car you will never be able to get back from -2.9 to -1.9 camber with the stock A arms.
I installed custom front upper control arms in order to get to -1.6 camber..
Old Aug 12, 2019 | 07:15 PM
Rear tire size fixed.
Aren't you lowered near 37mm? Do the stock alignment adjustments have enough range so that a 25mm or less drop wouldn't need the control arms?
Old Aug 12, 2019 | 08:25 PM
ronin amg's Avatar
Yeah I am as low as drivable.
The stock only has toe adjustment, that's it. If you go any lower you keep increasing the negative camber.
The only way to get the camber correct is with replacing the upper control arm.
