I still experience the no boost exhaust valve issue that is common on these cars. It doesn't happen all the time but still annoying to remember that it may happen when you push the car.
My question is, does the Renntech EVM solve this issue? Has anyone used this module? From what I see it bypasses the stock valve so when you hit open on the controller, it will always stay open.
I have modified exhaust on my car and original valves were replaced with different ones. It now shows fault codes on Engine Control Unit and car does not have boost/power.
Will this device solve this and bypass the issue or I am stuck?
hey, did this ever fix your issue? Having the same problem. Thanks
