E53 to E63 s front conversion w213
Old Apr 8, 2020 | 01:33 PM
Alex Moskovenko's Avatar
E53 w213
Exclamation E53 to E63 s front conversion w213
Hello all!
i have a question regarding if it is possible to fit the E63 s w213 bumper, grille and front wings to the E53 w213. Has anyone does this? Are the fittings the same or did it take a lot of work?
really appreciate the help in advance!
cheers!
Old Apr 8, 2020 | 03:38 PM
BC-2's Avatar
2018 E63S
I don't know how much work it would be but with enough money, I'm sure it's possible to swap front ends. The practicality is a whole different story though. You would need to replace the entire front end. Hood, both front fenders, headlights, bumper, grill inserts and all the other misc bits and trim. Then, any modifications required to fit everything. I'm not going to price everything out but I suspect you would be much better off selling your E53 and just buying a E63S. It would probably be cheaper this route and you would have a real E63S and all the performance that goes with it.
Old Apr 9, 2020 | 05:07 AM
E53 w213
Thanks for the reply, well the car has already dropped in price by $24 and I’ve only driven 2000km’s so would be a shame to sell it. Happy with it overall it’s just the front end which I’d replace. The bonnet shape and headlights seem to be the same, but I may be wrong.
Old Apr 9, 2020 | 09:17 PM
Wolfman's Avatar
Super Moderator
Headlight are the same shape, no matter which ones you have. The front bumper/clip is unique to the E63s and so is the hood. I believe the fenders are also a bit more aggressive but I can't tell for sure. Then add all the grill inserts, etc. Overall quite a few parts. Then you also have the rear (diffuser/exhaust pipes, etc). Costs will vary wether purchased new or used.
Couple pics for comparison...
Old Apr 10, 2020 | 02:50 AM
peejalino's Avatar
Veteran: Air Force
AMG GT63S
e53 to e63 conversion..mm, why not just have gotten the e63?
Old Apr 13, 2020 | 06:53 AM
immaengineer's Avatar
2017 E43AMG
I can confirm, totally different exterior front end. Not impossible to convert though if you can find the parts.
