2018 E63S Sedan Squeaky Brakes
Old May 6, 2020 | 04:49 PM
dw_22801's Avatar
2016 E63
So it sounds like my brakes are squeaking, so i took it into the dealership, and of course they cant duplicate the sound. They did tell me that squeaking brakes are normal on this car though. Please tell me that squeaky brakes are not normal on a $ 75k car with 18k miles. Help!
Old May 6, 2020 | 05:16 PM
bobblehead's Avatar
go fast grocery getter wagon
BIg brakes always squeak. It happens on bmw, Porsche, Audi, etc. Need to bed them in with high speed stopping a few times. I do this step maybe couple of times a month... usually in parking lot or on open roads with no traffic at all
Old May 6, 2020 | 06:02 PM
dw_22801's Avatar
2016 E63
Interesting. My 2016 never squeaked once. The dealer said that it can happen some when the brakes are cold, but once they warm up, it will stop. Mine is the exact opposite. They don't start until I've been driving around for a bit, and it does not stop and they are quite loud. And it is when I'm coming to a smooth stop. If I hit them kind of hard, they don't squeak, but I don't want to slam on my brakes to stop each time. I'll try the slamming on them a few times like you mentioned, but that seems odd that you would have to do something like that to keep brakes from squeaking. Which Mercedes have you had that does this?
Thanks!
Old May 6, 2020 | 07:04 PM
bobblehead's Avatar
Currently 18 e63.
It also happened to my bmw m5, Porsche Macan . M5 was the absolute worst.
i also spray Sonax wheel cleaner on the rotors too to get rid of the iron particles on them. It does help for awhile, on top of periodic bedding of brakes
Old May 6, 2020 | 08:24 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
My CCBs don't squeak. Are your steel or CCB?
Going through a bedding in process as mentioned above will help. One problem some people have is that they don't use their brakes enough to get them good and hot and burn off accumulated resin and gunk.
My motorhome brakes were squealing and the chassis manufacturer suggested that because it's common for a lot of folks to use the exhaust brake regularly the main brakes don't get a good work out and resin accumulates. Described the bedding in procedure to me, which wasn't that different from what I have done on other vehicles and I gave it a go. Problem solved, plus braking performance went up noticeably.
On the E63 I regularly get the brakes warm then brake right up to lock up to keep in practice. Kind of similar to the drills that we did during the AMG Academy, but not as repetitive.
Old May 6, 2020 | 08:51 PM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
I’ve got one wheel/brake (steel) that has squeaked from almost day one under very light brake pressure. It has been changed, swapped, redone, blown out, washed, replaced whatever they could think of. I just finally gave up and just turn the music up or press the brake pedal a little harder.
Old May 7, 2020 | 12:27 AM
dw_22801's Avatar
2016 E63
Thanks for the replys. How do I know if they are ceramic? Would I just have to take the wheels off to look or is there some other giveaway ?
Old May 7, 2020 | 12:49 AM
aaronpass's Avatar
2018 E63 Wagon Stage 2
gold calipers are ceramic, red are steel
Old May 7, 2020 | 11:13 AM
dw_22801's Avatar
2016 E63
Ah, steel then.
Old May 14, 2021 | 04:41 PM
krazykrnboi's Avatar
2018 Mercedes-Benz E300
wrong thread
Old May 17, 2021 | 04:42 PM
E63Wsantini's Avatar
Range Rover 400e, Ferrari GTC Lusso, G63
My 2018 wagon only squeaked after a HPDE weekend.
Old May 17, 2021 | 04:56 PM
cyclrder's Avatar
18 E63s Wagon 15 GL63 (sold), 10 Turbo TT MT, A36 Bonanza, 20 JLU Rubicon
Porterfield R4S here on my wagon... they squeak too though I might need to do another rebedding process. They are a lot less brake dust though and it makes up for it.
Old May 17, 2021 | 05:24 PM
I ordered Giro disc, rotors with their SS-1405 front pads and MP-2047 rear pads. Hope they perform better than the OEM.
Old May 17, 2021 | 11:54 PM
scoobyhumme's Avatar
W213 E63s
my ccb (18 edition 1) squeaks a lot during the summer when the car is at low speed, esp stuck in heavy traffic. but as long as brake temp going up, the noise goes completely. is there anyone here as same as my situation?
Old May 18, 2021 | 09:57 AM
nw66's Avatar
E63S 4MATIC 213
Brembo's do squeal my race bikes are even worse than the E63! wouldn't worry about them!
Old May 20, 2021 | 11:05 PM
W213 E63s
gotcha. that makes feel comfortable, lol.
cheers matey.
Old May 21, 2021 | 03:26 AM
nw66's Avatar
E63S 4MATIC 213
cheers matey.
Old May 22, 2021 | 11:59 AM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
My CCB's are starting to squeal at light pressure now that I have about 4K miles on my 2021 E63S wagon. The brakes have been totally silent until 2 weeks ago. Applying the brakes harder stops the noise. I've tried bedding the brakes with a series of hard applications which has minimized the noise and made it less frequent, but it's still happening a times. Suggestions?
Old May 24, 2021 | 08:16 AM
HBerman's Avatar
I repeated the hard braking applications again this weekend and the noise has not repeated. I suppose that I didn't try enough additional hard brake applications the first time around.
