High Flow Air Filter Installation Instructions
Old Jun 20, 2020 | 12:55 PM
aaronpass's Avatar
2018 E63 Wagon Stage 2
Hey everyone, a few people have asked what steps I took to install my high flow air filters, so here we go.
  1. Remove main engine cover. This just pulls off at 6-8 different points around the edge.
  2. The air boxes are located on the front of the engine.
  3. Loosen the hose clamps that connects the air boxes to the short rubber hose. You don’t need to remove them, just loosen them plenty.
  4. Pull the air boxes up and forward to dislodge them from their rubber mounts.
  5. You will now be able to access the 4 torx screws that hold the front of each air box on. Unscrew these, they won’t come all the way out but enough to pull the front of the air box off.
  6. Pull the old air filters out and install the new ones.
  7. Do the above steps in reverse for reinstallation.
Done! Took me about 30 min. Pretty simple job. Hope this helps some folks.
Old Jun 21, 2020 | 03:11 PM
JsteinMD's Avatar
2019 E63S, 2014 GL550
Air filter ??
Thanks for the info. A friend of mine was telling me about this when we went for a drive with my E63S and his 911 Turbo. What does the air filter change get you - improved exhaust, added HP, better engine cooling? Do you have a recommendation for the air filter replacement? I appreciate the info!
Old Jun 21, 2020 | 03:30 PM
aaronpass's Avatar
More air to the engine = more power. It also makes it so you can hear the turbos spool a lot better, which is awesome. PM Shardul on this forum and he can hook you up.
Old Jun 21, 2020 | 04:38 PM
JsteinMD's Avatar
Thanks will do!
Old Jun 24, 2020 | 03:34 PM
wrightatl's Avatar
2019 Mercedes E63S Estate
@aaronpass you notice the difference?
Old Jun 24, 2020 | 03:36 PM
aaronpass's Avatar
Yup! Much better sound from the turbos too :-)
Old Apr 21, 2021 | 12:49 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
@aaronpass thank you for the instructions, I just did Weistec air filters and VTA’s tonight in my garage.
