Tires Make a BIG Difference
Then one day I had to drive on wet pavement. While the stock Michelin Pilot Sport 4Sare phenomenal on dry pavement but virtually useless on wet. I was slipping all over the place. Then I got a huge nail in the front tire. Which was repaired, but the repair did not hold. So I was going to have to buy a new tire.
I decided to swap off the stock tires to the Michelin Pilot Sport All Season 4. I did this on my previous CLS and was totally satisfied with them.
Wow. What a difference.
Unsurprisingly, I lost some dry pavement handling with the all season tires. That was a bummer, but it is not that noticeable. I don't drive that aggressively. However, the all seasons are significantly quieter and smoother.
I just completed a 600 mile road trip on these new tires and the car was a wonderful cruiser, but still able to get raucous when necessary.
The Potenza RE980AS+ molds the updated all-season compound into an asymmetric, noise-optimized tread pattern to balance dry and wet performance with quiet comfort. The tire's lateral slots are chamfered to improve rubber-to-road contact and aid in dry braking, while the 3D full-depth sipes interlock for tread stability. High sipe density creates the biting edges for traction in slippery conditions, and their full depth helps maintain performance over time. The Potenza RE980AS+'s tread pattern slots and grooves are interconnected to facilitate water evacuation from the contact patch, and open shoulder slots combine with high levels of see-through void to further reduce the risk of hydroplaning".
