Winter Tire Pressure
Hello all
Just swapped back to a set of dedicated 19" winter wheels and tires. Looking for suggestions on ideal tire pressures for the winter set. Up to three people in the vehicle and "reasonable" speeds until the spring and the summer wheels/tires return.
Thanks in advance
Sean
Indy, IN
Thanks in advance
Sean
Indy, IN
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
Hello all
Thanks in advance
Sean
Indy, IN
Thanks in advance
Sean
Indy, IN
I'm running 40 front and 39 rear cold. That is the bare minimum I would go or you will be looking at a possible blow out and tow (no spare, no runflats, and not even a jack!).
I run on 19” with 41psi front and 37 psi rear , Oem recommended wheels.
Thank you for the replies received. Decided on 42 psi front and rear. Seems to be working well in terms of comfort and providing more rim protection than the stock 20" and low aspect tires provided.
Sean
Sean
