front wheel camber/tire wear/camber bolts . . .
One thing to understand is lowering/swapping out the a-arms may break a part of your warranty. MB warranties everything based on the OEM equipment. Take it to a dealer and they likely will push it back to you as it now has non OEM parts. If you have a good relationship with the service department and they installed the arms you may be OK. Best case they'll cover everything, worst case all costs for suspension repairs is on you. Then again, how often does one have suspension problems?
Except for #503416-1G kit which is Camber only.
LABOR / INSTALLATION TIME REPRESENTS THE BIGGEST COST OUTLAY (complete upper A arms requiring removal of the airmatic Struts as well) along with warranty issues.
Therefore above #503416-1G besides being budget priced at $295 (both sides) - has advantage of fitment without need for arm removal and no special tools required. Replacing the lower arm inner bushings. Also unlike upper A arms when adjusting to resolve premature inner edge wear importantly retains clearance top of tire to outer fender.
Replacing these lower arm inner ‘2’ bushings (also the highest wearing) provides precise easily accessible single wrench adjustment - “accurately under load, direct on alignment rack” !!
NOTE: KMAC upper A arm inner bushes #503316-2J $380 (Camber and also Caster adjustable) there is no need for A arm removal - but still requires Strut removal.
While ultimate W213 AMG #503416K $480 includes above #503416-1G Camber kit along with the 2 forward facing “thrust arm bushes”. Which are designed to be precisely Caster adjustable and “Monoball / 2 Axis” - significantly improving “brake and steering” response.
No front Camber and Caster, no rear Camber to cater for other then showroom height conditions.
Day to day commuting encountering high cambered roads, wheel squat through load carrying or lowering, fitting wide profile tires and even the lack of “ongoing adjustment capability” for curb knock damage.
For W213 models including AMG E43 / 53 / 63 there is not even offset bolts for front offering a minimal .3 of one degree change !
So "dealer won't try anything else" - he simply has nothing to adjust / try to resolve costly, premature edge tire wear !!
I’ve had over 20k miles on my tires now, with the car lowered and the F1-Fab upper control arms installed. Zero problems and completely even tire wear 20k+ miles.
Granted KMAC front upper A arms are dearer but you get what you pay for - Camber plus also Caster and being a “critical suspension component” - avoiding dealership warranty issues not welded, fabricated, but security of being manufactured (same as OEM) from Hi strength forged alloy.
Seeing installation / fitting time is the most expensive item as a alternative to above we THEREFORE manufacture:
FRONT LOWER ARM INNER ‘2’ BUSHINGS CAMBER ADJUSTABLE CHECKLIST RE ADVANTAGES:
•PRICED RIGHT AT $295 (Both Sides) Less cost then ‘1’ Hi performance tire.
•AGAIN “RETAINS SECURITY” OF THE OEM FORGED ALLOY ARMS
•FIT TIME - NO NEED FOR ARM REMOVAL !
•NO SPECIAL TOOLS REQUIRED
•EASILY ACCESSIBLE PRECISE SINGLE WRENCH ADJUSTMENT
•ACCURATE ADJUSTMENT - UNDER LOAD DIRECT ON ALIGNMENT RACK
•INNER EDGE WEAR - UNLIKE UPPER 'A' ARMS "RETAINS" TIRE TO OUTER FENDER CLEARENCE
•RACE DAYS (REDUCING UNDERSTEER) ALSO ALLOWS “INCREASED” TRACK WIDTH.
•THIS POPULAR “NEW SERIES ‘2’ KIT” - OVER 200 SOLD LAST 12 MONTHS
KMAC - Resolving OEM Suspension Shortcomings Since 1964 AUDI to VOLVO
Using hunter equipment
I had my car undergo an alignment due to poor tyre wear. Was told the front can not be done properly as these cars do not have the parts from factory to carry out the alignment. Kinda felt like it was bs cos I never heard of this before.
He said I need to get a part that will allow him to make the adjustments needed. What is this part that’s needed?
seems like the camber is out on both front and rears, do the rears need a part too?
K-MAC ALIGN - Camber Plates & Caster Strut & Bushing Kits (k-mac-camber-kits.com)
You would need a camber kit like @ygmn posted or aftermarket adjustable a-arms to adjust the camber.
It's definitely worth the investment over time, as you'll quickly spend more on replacing tires too often.
We completely re designed and now one integral unit !
Like the new car industry it’s all about constant / ongoing development !
Kevin
Yes Camber & Caster Front
#503416M
Camber & Extra Toe Rear
#502326-1K
Both front and rear kits - no special tools or need for control arm removal to install.
Precise single wrench adjustable. Ultimate - direct on alignment rack UNDER LOAD.
Kevin
Hopefully you have another dealer nearby that is a little more competent.
