19" staggered wheels for 2018 e43
Am looking to replace my 20" staggered set up on my 2018 E43 AMG to a 19" staggered set up as well in order to get a better ride quality. Any ideas out there would be helpful as I am having difficulty finding the right offsets for the fronts and don't want to have to install spacers as that would probably affect the 4matic drivability. Any help would be appreciated or if anyone has wheels they are selling, that would be helpful as well.
go fast grocery getter wagon
245/40ZR19 8Jx19 ET20
275/35ZR19 9Jx19 ET49
note: if you choose an aftermarket wheel which is wider in width than the factory width, then you will have to look at a lower offset number. In the end, your wheel may still end up to be extended outward.
Thank you. I saw that tin the wheel spec sheet. I guess what I was trying to find out is if anyone had any ideas on wheels that are within those sizes without the use of spacers. If I stick to the standard offset, then I should not have to use spacers and the wheel will stay within the fender side and stick out, right?
Of course no spacers are required if you find aftermarket wheels with same or very similar offsets. But for mb wheels, esp. Amg, they are very odd offsets used, therefore, you will have a hard time to find the exact spec … unless you go custom order an aftermarket set.
secondly, wheel designs and type of materials construction may also matter as well. Hence, they add more research into a wheel that meets your needs.
