Cruise Control
Finally found the option for the Traffic Sign based limit change and turned that off.
The feature was great while driving in Europe during my ED tour and likely saved me countless speed camera tickets where I frequently didn't see the sign posting limit change.
My 2018 doesn't have the Route based adoption feature, only the Traffic Sign feature, and with that turned off cruise control works pretty well for me, particularly in traffic. I'll set the Distronic to some reasonably high value and the following distance short enough to keep all but the most aggressive lane changers from cutting in front of me and then the car will adjust to the flow of traffic quite well.
When the road is open, my only complaint is that it never goes into eco mode or coast mode like it would if you are driving manually. It also holds the speed down hills. So as a result, driving manually you can do a little better on fuel mileage. But not a lot - at least in my non scientific tests.
I tried using the auto-steer, but that's not real useful on actual highways. It worked great when the striping was perfect, mainly stretches that had been recently maintained. For the rest, I could just hear an engineer yelling, "in Germany vee don't allow faded striping!" as the car aimed for the guard rail.
It would probably be OK in some flatter areas where the corners tend to be larger radius turns.
But even on the Interstate I keep a pretty good eye on it because as noted it will head for the hills if the striping isn't well marked and other than the indicator turning amber doesn't give me any audible beeps as a heads up that I've got the helm.
When driving 10 to 12 hours in a day with only the occasional stop for fuel and grub/coffee, your right foot will tire and even switching to throttle with the left foot starts to get old.
Really happy when the dealer in Dallas got it all sorted back out again and I was able to make the rest of my drive from Dallas to San Diego with full distronic features available.
We've loved every trip taken with this car, it really eats up the miles. Getting the Flowers for Algernon treatment for the lobotomized LED headlights helps a lot too when driving on the highway at night.
https://www.mbusa.com/en/owners/manuals
