Check coolant warning message
Old Jul 29, 2022 | 05:32 PM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
Today I received a warning message to check my coolant level. When I looked at the reservoir, the level of the coolant was significantly down from the minimum level. The level came up after I drove the car for a while, but that was obviously normal expansion. The shop foreman at my dealer mixed up a batch of coolant to add to the reservoir which appeared to take somewhat less than a quart to top off the level. There were no leaks discovered upon inspection, but I had noticed that the fill cap was difficult to remove so it might have been installed improperly and leaking from there. Replacing the fill cap was smooth and it clicked into place so it might have been just the cap being installed incorrectly.
Old Jul 29, 2022 | 05:59 PM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Any smells or stains? Most common issue of course is a puncture in one of the radiators up front.
Old Jul 29, 2022 | 06:00 PM
bobblehead's Avatar
go fast grocery getter wagon
I also filled mine up a few times over the last 4.5 yrs. I think that’s normal too. No difficulty in removing the cap from the coolant reservoir
Old Jul 30, 2022 | 07:55 AM
HBerman's Avatar
Nothing that was visible. The level is holding after the replenishment. The shop foreman stated that it is not unusual to have to add a small amount of coolant on these engines.
Old Aug 12, 2022 | 01:40 PM
TheRod's Avatar
2021 G63 AMG - Matte Black
UPDATE: they found code C151E01 for left front level sensor malfunction. When they raised the truck using the lift the value indicating clearance (i think) didn't change. They had to remove the driver seat to gain access to the adaptive dampening module. They found an open circuit from the connector to the level sensor. The electric pin bushing wasn't locking properly. They replaced the electrical pin bushing and the problem was resolved.
It's still unclear if this was the result of sloppy work from replacing the thermostat. It most likely is but MB service wont admit it is.
Old Aug 13, 2022 | 12:18 AM
utsteve98's Avatar
Range Rover Velar SVAutobiography
I had a low coolant warning this week. Just slightly low when dealer checked. They checked all hoses and did a pressure test and no issues. Must be accurate about these engines needing coolant every so often.
