[NEW] PTG W213 METHANOL SYSTEM
E63S, Huracan Performante Spyder
Selling W213 Water Methanol System from PTG.
I never installed it so its brand new.
Price : 2299$ US
I'm located in Quebec, Montreal but I can ship it to US for free
https://www.premiertuninggroup.com/products/015-1807-1759
The engineers at Premier Tuning Group have developed the most comprehensive methanol system for your Left Hand Drive W213 E63 AMG. This system is bespoke and designed specifically for the W213 E63 platform.
Starting with our hard anodized 2.5 Gallon aluminum tank to feed the thirst of your highest power E63. Our tank provides a large 4 inch tilt cap for a no mess refill and nests itself nicely in an open compartment under the trunk mat of your E63. This means no tank in your car and provides an NHRA approved system.
From here we share details of what is included in the entire package. Brown & Miller plumbing allows you to run 100% methanol with no worry. A 50 gallon per hour pump is the highest possible flow rate in the market and it is a standard option in our Methanol System. The gravity fed system places the pump away from the engine bay in the wheel well and provides filtered fluid to your engine.
Aerospace hard anodized fittings and our PTG high flow Y fitting give you the flow needed to support the most rigorous needs from your E63. Included is a set silicone couplers to adapt the system to your stock turbos and to screw right into your PTG turbos. Users also have the ability to customize the system with 500-800cc or 1,000-1300cc nozzles depending on horsepower targets.
This is the most comprehensive methanol system for your E63.
System Includes:
2.55 Gallon Bolt-In Methanol Tank
Billet 4 inch Tilt Cap
Largest Possible Methanol Safe Pump Standard
Brown & Miller Fluid Transfer Lines
-6AN Feed with 10 Micron Filter Standard
PTG High Flow Y-Fitting and -4AN Feed Lines Standard
4 Ply Silicone Couplers for Stock Turbo Nozzle Placement
500-800cc Nozzles
Price : 2299$ US
System Includes:
500-800cc Nozzles
Yes, the tank for the sedan doesn’t work for the wagon. There isn’t a spot for a tank really at all without moving stuff around under the cargo cover. At least that’s what PTG told me…
