All seasons / winter tires
Michelin - Pilot Alpin PA4 - 245/35R20 91V BSW
Michelin - Pilot Alpin PA4 - 275/30R20 XL 97V BSW
They don't get here until next week so I don't know how well they will do. Anyone try this before?
check the production date when you get them. Anything over 3 yrs old should be sent back to vendor. Rubber compounds may start to degrade over time.
All that being said, snow was of zero concern but I'm sure they could handle a light dusting.
Results: https://docs.google.com/spreadsheets...#gid=742439515
UPDATE: Not selling anymore.
I just swapped P-Zero summers out for DWS06+ A/S tires on my wagon and the steering/driving feel of the car changed dramatically. The car on feels floaty and not nearly as planted, inspiring very little confidence at faster speeds, especially when going through even light highway cornering. Google tells me that tires have a 'break-in' period of 500 miles and that this problem should go away. Was any of this similar to your experience with the DWS06+? While road noise is greatly improved vs. Pzeros, the impact to handling is a big negative in my book. However, I only have ~200 miles on them so am holding out hope that their handling improves as they get 'worn in'.
By the way, what tire pressure (psi) do you both run? Installer had them at 50-55 psi. I put them down to 44 front / 40 rear almost immediately, which did help some.
We saw the need therefore and manufacture adjuster kits to resolve the excessive edge tire wear allowing TO FIX IT RIGHT THE 1ST. TIME !
With ongoing adjustment to cater for high cambered roads and excess passenger side edge wear or all the other situations encountered in day to day commuting - wheel squat through load carrying or lowering, fitting wide profile tires along with adjustment for curb knock damage or performance / track days the ability to be able to adjust change settings.
W213 4MATIC, E43/53/63, E220-450
FRONT CAMBER ONLY #503416-1 $345 (Both Sides)
Less then cost of one tire. Fit without need for arm removal.
FRONT CAMBER (& Caster) #503416 $480 (Both Sides)
Both above kits are precise single wrench adjustable - Accurate direct on alignment rack under load. Caster bushes are also Mono ball / Self aligning significantly improving brake and steering response.
REAR CAMBER (and Extra Toe to Compensate) #502226 $480 (Both Sides)
Airmatic #502326 $480 (Both Sides)
Can also fit without need for arm removal and also precise single wrench adjustable (on alignment rack under load)
*E63/65 W212 See website (and all other Mercedes Benz Models 1968 to 2023).
Delivery US, CAN. MEX, UK, EU, ASIA/PACIFIC $40 one kit $60 Front & Rear
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
