w213 transmission fault code
Old Nov 15, 2022 | 05:06 PM
larsianer's Avatar
w211
I got a w213, 220d 2017, with a faultcode p060c00 there is an internal control unit central processing unit
is it the ecu in the conductor plate that is gone bad?
sometimes i cant put the car in drive or reverse, and if i turn off the car for a while, it works again, no limp mode
i have tryed to erase the fault code with my sds, but it will come back at the same time
so if its the conductor plate ecu, anyone got the part nr for it?
and can i recode it without scn, or is it someone here who knows how to do it?
Lars
Old Nov 15, 2022 | 06:14 PM
W205C43PFL's Avatar
Lars
not sure if it is related but here are some threads on this code:
https://mbworld.org/forums/gls-class...ml#post7420296
https://mbworld.org/forums/w213-amg/...ml#post7989725
