E63s - why is jack socket covered with plastic?
Old Jul 13, 2023 | 12:30 AM
Archerrrus's Avatar
E63S
Hello there!
In preparation to check the winter wheels fit, I was surprised that jack point wells are lined with plastic. Why would they do this?
I have a pair of these : https://jackpointjackstands.com/prod...ock-pads-pair/ and I'm wondering if metal part will cause the plastic to crack.
Old Jul 13, 2023 | 12:53 AM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
I use metal pads that fit into well. Seems ok. I have rubber one too though.
Amazon Amazon
Old Jul 13, 2023 | 04:12 AM
superswiss's Avatar
2019 C63CS
Nope, plastic won't crack unless you don't center the jack properly. I don't even use an adapter. Just the bare jack. I did crack one a bit, because I was off center and the jack slipped, but that plastic is surprisingly strong. I think it's there so that you actually don't need an adapter.
Old Jul 23, 2023 | 02:50 AM
Archerrrus's Avatar
E63S
Checked if the winter wheels fit today, update to the jacking story.
I ordered this pad from Amazon:
Amazon Amazon
. But, while it fits quite snugly, the circular base is not high enough, it doesn't clear side skirts. Plus, the rectangular area in the middle doesn't reach all the way up, so the car is supported only by the circular base.
So, given that this plan didn't work, I wanted to see what's under that piece of plastic. Turns out there is an oily hole (I suppose to prevent water from entering).
Putting the plastic jack pad back was not trivial, as the attaching mechanism stayed inside - it's similar to the one used by dry wall bolts (expands as the fastener is tightened).
After putting it back, I used the Jackpoint Jackstand plate I linked at the begging of this thread. After lowering the vehicle, I checked the plastic piece again - besides some texture change, it's good as new:
So, while extra care is needed when lifting the car, both Jackpoint and Reverse Logic (https://reverselogic.ecwid.com/Jack-...C218-p21256090 ?) pads will work. But, it seems that Reverse Logic exchanged hands recently, so product availability is non-existent. What I like about Reverse Logic's pad is that it has more surface area, while Jacpoint plate has a space in the middle to support weld lifting points.
